Nearing completion.
Old 10-07-2011, 06:50 AM
mechelement's Avatar
mechelement
mechelement is offline
That looks great!
  #62
Old 10-07-2011, 07:46 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
86f250XLT-4x4 is offline
I hope you get it going this weekend I can't wait to hear how she does for you!!!!
  #63
Old 10-07-2011, 08:24 AM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
Looking good man, I hear those turbos really whistle.
  #64
Old 10-07-2011, 09:19 AM
88beast's Avatar
88beast
88beast is offline
if ur worried about the stand cut a 2x4 to fit under the crank pully if youre not moving it or using the crank its a ton more stable
  #65
Old 10-07-2011, 07:58 PM
Coalroller's Avatar
Coalroller
Coalroller is offline
WOW!!!!!!!!!!!!!!! thats the about all that comes to mind!
  #66
Old 10-07-2011, 09:42 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
WOW
looks great man. i am pretty much speechless.
What are you going to use for injector lines?
Are you going to put you pyro in the "standard" location in the drivers side manifold?
  #67
Old 10-07-2011, 09:43 PM
'94IDITurbo7.3
Ya, they sound just like turbo keychains.
  #68
Old 10-08-2011, 03:41 AM
1BadB2's Avatar
1BadB2
1BadB2 is offline
  #69
Old 10-08-2011, 04:13 AM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
LOL good ol' 80cc
  #70
Old 10-08-2011, 09:08 AM
Coalroller's Avatar
Coalroller
i see dirty's truck in the background lol
  #71
Old 10-08-2011, 08:49 PM
91dirtydiesel
all those engine pics and you spot out half a truck in the background...lol thats funny
  #72
Old 10-09-2011, 03:28 AM
1BadB2's Avatar
1BadB2
1BadB2 is offline
we had our first go tonight at putting the engine in. It kicked our asses.
Ended up pulling the trans completely out, and having the pull the engine back out when we found the clearance issues.
The Bad:
It wouldn't fit.
The Good:
I can make it fit!
I need to pull out the reduction starter and put my nippon denso starter on. Its about 1.25" shorter which will make removal possible without an engine hoist in the future. Everything clears other than that driver side manifold. I ended up modding/building new motor mounts which locate the engine 2" further forward. RacinNdrummin hammered the firewall, and I guess it fit with the tape measure, but when it came down to it, dropping the engine in, we were about 1/4-1/2" away!! What a bummer.
So, tomorrow I'm going to swing the sledge at that little corner on the firewall and see what kind of clearance I can get out of it. If I have to, I will perform surgery on it.
The Goal for tomorrow is to at minimum have the engine bolted in. Depending how well the firewall work goes, I could also have the trans and driveline done.
  #73
Old 10-09-2011, 08:11 PM
Coalroller's Avatar
Coalroller
haha i figured id point out the not so obvious
  #74
Old 10-09-2011, 11:30 PM
1BadB2's Avatar
1BadB2
1BadB2 is offline
I beat that firewall like it owned me money
Going to be a tight fit for that big downpipe
Needs to be bolted down at the motor mounts to pull it straight, but that is for tomorrow... I'm just happy its all sitting in its mounts, trans is bolted on, and everything clears!!
Russ (typ4) is coming over to my house tomorrow to hang out a bit, and bring me a return line kit as well as injector port reamer. Also, ARP studs will be here tomorrow for the intake.
  #75
Old 10-10-2011, 12:30 PM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
Its looking awesome. I wish I could see that thing in person too. Lol.
Quick Reply: Nearing completion.
