1965 F100 300 6 cylinder accelerator cable
Hi, I need some help in locating a replacement accelerator cable for my 1965 F100 300 CI six cylinder truck. My cable broke. The part number is C5TZ-9A758-AG, which is listed as obsolete. The cables available from parts dealers are shorter for the 8 cylinder engines.
I have tried looking at local salvage yards but so far no luck. I was planning to use my truck for a hunting trip later this month and need to get back on the road.
Any advice or help would be appreciated!
The reproduced cable available from parts dealers is shorter for the 352 engine (20" - C5TZ-9A758-AH).
C5TZ-9A758-AG (replaced C5TZ-9A758-C, C5TZ-9A758-AA) .. Accelerator Cable-28.66" long / Obsolete
No Ford Dealer or obsolete parts vendor has any of these part numbers.
Applications: 1965/66 F100/250 240/300 I-6 2WD.
There is another 28.66" cable (C6TZ-9A758-K), it is not the same, as it fits 1966 F100 240 with T/E (Thermactor Emission-smog pump).
NOTE: ebay sellers usually have no clue, so be very careful if buying a cable off ebay.
Most ebay sellers have no parts catalogs, and if the cable is NOS, has a part number on it, they usually assume it's for an F100...sometimes it is, sometimes it isn't.
2WD is different than 4WD. N Series, P Series Parcel Delivery's, Econolines also used these cables. The part numbers prefix is the same for all: C5TZ, but the cables are not the same for all!
Bob's F100 lists a reproduction cable for 6 cylinder models. You may want to call them. Here is the link:
http://bobsf100.com/table_of_contents_cat5766.htm
About Bob - Bob's F100 Parts - (951) 681-1956
C5TZ-9A758-AG = 1965/66 F100/250 2WD 240/300 except 1966 F100 240 I-6 with Thermactor Emission-smog pump.
C6TZ-9A758-K = 1966 F100 240 I-6 with Thermactor Emission only.
Bob has invented a part number: C6TZ-9A758-AFG says it fits 1965/66 F100/250 240/300. Uh huh...
So, which cable is this? C5TZ-9A758-AG or C6TZ-9A758-K / They do not interchange!
65 Econoline
11-20-2016 09:00 AM
65_GarageArt
02-05-2013 04:55 PM
78F150TX
01-18-2013 07:58 PM
1965, 1968, 300, 9a758a, accelerator, c5tz, cable, cyc, econoline, emissionsmog, f100, ford, pump, thermactor, truck
