Dana 60 swap
Old Sep 25, 2011 | 08:53 AM
99hosss's Avatar
99hosss
Dana 60 swap
Hello forum , any chance a 71 dana 60 hub to hub will fit my 66 250?
Old Sep 25, 2011 | 11:08 AM
CropDusterMan's Avatar
CropDusterMan
Are you doing a complete swap-axel to axel? If so, it'll bolt right up. You are going to run into an issue
with the Differential yoke/drive shaft, as the later model diff. has a different spline count...easily fixed
with the use of a conversion U-Joint for the drive shaft to diff yoke. There will also be a few issues with
emergency brake cable lengths...the 1971 will need longer cables-one is longer than the other.
I did this swap a year ago to get better road gearing and better brakes.
Old Sep 25, 2011 | 04:53 PM
99hosss's Avatar
99hosss
Thanks partner. Will my original drive shaft work? Also, can I use the 71 brake cables?
Old Sep 26, 2011 | 07:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by CropDusterMan
You are going to run into an issue with the Differential yoke aka companion flange/drive shaft, as the later model diff. has a different spline count easily fixed
Some 1966 F250's have 10 splines, some have 29 splines as do all 1967 and later F250's.
It also depends on the size of the u-joint cups if 29 splines. 1966/72: There are four different 29 spline 'companion flanges.'
1966/70 F250 4WD 1330 cups / 1966/70 F250 2WD 1310 cups / 1971/72 F250 1310 cups / 1971/72 F250 1330 cups.
Old Sep 26, 2011 | 07:28 AM
99hosss's Avatar
99hosss
Sorry guys, I'm still confused. Are you telling me that my drive shafts' yoke, with the 2 u-bolts won't fit into the 71 diff. where the u-bolt nuts go thru? Also how bout using the 71 emer. brake cables? Thanks again
Old Sep 26, 2011 | 07:33 AM
NumberDummy
The yoke aka companion flange has either 10 or 29 splines to match the R&P's pinion gear.
The flange splines slip onto the splines of the pinion gear,
Why do you need to change the brake cables? 1967/72's have a 2" longer wheelbase, so the cables will not work on 1965/66's.
Something else to consider...what size are your brake shoes? 12" x 2 1/2" brakes introduced in 1966, but not all F250's have them.
Some 1966/72's have 12 1/8" x 2" shoes front/rear. Some have 12 x 2 1/2" shoes front/rear.
All Camper Specials have the 12" x 2 1/2" shoes, other F250's could have either, as it depends on the GVW.
Old Sep 26, 2011 | 09:43 AM
99hosss's Avatar
99hosss
Thanks guys, I think the seller has the Dana still under the truck. If not , What do i have to do, take my drive shaft out there? That would be no problem, also Crop duster said my cables wont work. What route do I take on the cables?
Old Sep 26, 2011 | 10:56 AM
CropDusterMan
Dana 60 Swap-Companion
Well, sorry guys...I'm the one who caused some confusion here in the first place, and thanks to Bill (NumberDummy) for setting it straight.
Ok, so here are a few images and that may help me clean up my mess....
I mentioned replacing the E-brake cables as the ones on my donor Dana 60 (3.73)axel were rusted....these are longer than the original ones on my original Dana 60 4.56 axel.
The Diff. Yoke + "Companion flange" photos show the spline that I spoke of, the original was a 10 spline (pictured Below), the new one is a 29 spline, and there is also a photo of the u-joint conversion in the next posting.
Also, my truck doesn't have the original engine or trans. (now has a 302/C4), so I don't even know if my Dr. Shaft is original. What the heck did I get involved for!
Old Sep 26, 2011 | 11:05 AM
CropDusterMan
Dana 60...
Here is the U-Joint conversion I used, along with a photo of my original 60...it has the smaller brake drums.
Jason
F-250 restorer
Mar 7, 2017 08:39 PM
Scotty's 52 F3
Oct 25, 2015 01:20 AM
nossliw
Dec 6, 2011 06:17 PM
wildstang
Jun 6, 2010 10:03 PM
