stanadyne injection pump
Hello all,
I have an 87 f-350 with 7.3L. I have great fuel pressure all the way to the injection pump but nothing but a couple drops coming out the lines to the injectors. I tested the solenoid on top of the pump and it is working.
The odd thing is,... sometimes it will start. Then runs pretty good until it sits all night. But when it will not start I have no fuel pressure past the injector pump.
I know I am doomed (injection pump time) but in the hopes of something I missed. Is there any other reason I would not be getting fuel to the injectors intermittently?
Thanks for reading
Thanks for reading
A bad lift pump will not always put fuel in the crankcase. It does sound as if you have a leak somewhere. The last one I repaired had a leaking tank switch. Push the bleed valve in the morning and have someone crank it over, if you don't have fuel right away you have a leak. Does sound like a pump thou.
It does sound IP related based on the information given. If you run the e-pump for 10 seconds before starting and it doesn't fire off quickly, then you can be sure it isn't a leak causing the issue and you are looking at an IP replacement. Even with leak back, it should fire off after a crank or two.
If you replace the IP, you need to replace the injectors, too. It is pretty critical to do both at the same time of you like MPG and HP. Have the timing set as well.
I don't know about a screen, but the '87 in the signature keep cutting off aprox. 1/2 hour of running; always the same, highway speed let off fuel for decel or turn OFF. Hard start. Man runs a diesel shop told me over the phone to try this $25.00 a quart cleaner he had. Someone here, I think said try new filter with ATF. I filled new filter with 50/50 mix Diesel clean and ATF then accidentally poured 10 gal. hi sul off road in the tank. So far she has cut off once in 500 +- mile of driving short trips. Try cleaning her out first. We were using 5% Bio mostly before that. Now were are adding ATF to fuel. We generally change fuel filters every other oil change -aprox. 10K.
f250d4x4
09-13-2011 11:06 PM
lossscause
02-29-2008 04:08 PM
