Driveshaft balancing
Old 05-06-2014, 02:52 PM
SoCalJim's Avatar
SoCalJim
SoCalJim is offline
7th Gear
I just replaced the rear end on my 1997 F150 2WD. While it was apart I replaced the u-joints on the rear driveshaft. Afterwards I heard that I should have indexed the driveshaft as the whole thing is supposed balanced as an assembly. Is this true? Do I have to get it balanced again somehow?
Old 05-09-2014, 08:59 AM
Dave G.'s Avatar
Dave G.
Dave G. is offline
I've never run in to a situation, that by changing u-joints, something became imbalanced. I do however, mark everything with chalk, to at least assemble the parts in some sort of order. You have only 2 choices with joints/yokes, 180 deg. apart. I'd think by now any imbalance would be pretty obvious.
I've only had a few shafts balanced, but those were custom made.
Dave
Old 05-09-2014, 09:21 AM
Zrock's Avatar
Zrock
Zrock is offline
just make sure your front and rear ujoints are lined up and all should be good
Old 05-09-2014, 09:59 AM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
You could inspect the shaft for weights, they are welded on where needed in the manufacturing and balancing process when the shaft was made. Over time, they may come off through corrosion. If that shaft was out of balance it would manifest itself as a vibration at different speeds. Make sure you have the proper endplay in the u-joints before installing the whole shaft back in the vehicle. They must pivot freely without binding!
Old 05-09-2014, 10:33 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Try and keep everything lined up is a good rule, may have to rotate the d.s. is all. There used to be an old school trick, a big hose clamp installed on the driveshaft; can be rotated in thirds or whatever to isolate imbalance or somesuch, anybody remember this?? Anyway keeping vibration levels low as possible is important for bearing life and other components.
tobyw
2015 - 2020 F150
04-03-2019 04:12 PM
homertwo
1999 to 2016 Super Duty
11-03-2016 10:57 PM
TMattson
09-16-2009 05:24 PM
JeffMc202
05-06-2009 08:52 AM
shortbed1
Bronco II
04-17-2004 07:59 PM
Quick Reply: Driveshaft balancing
