Bronco II Ford Bronco II
driveshaft
Old Apr 17, 2004 | 07:37 PM
shortbed1's Avatar
shortbed1
driveshaft
Hi all, Ive got a 90 b11 4+4 auto 2.9 i have the cv driveshaft that is going bad cv front and rear of shaft do they make a regular driveshaft or will i have to go back to the cv shaft style. Any help would be greatly appreciated. chuck
Old Apr 17, 2004 | 07:59 PM
mjb1962's Avatar
mjb1962
You can get a conventional u-joint replacement shaft at a driveline shop for about $200-$250. You may need to adjust the rear pinion angle if you do though. With a single u-joint at each end of the shaft the u-joint operating angles must be the same.
Mark
