Hydroboost/Master Cylinder guidance
Old 01-05-2012, 10:37 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
I think we all might have a leaking(minor to major) hydo boost.
I just found out mine has been leaking a little for awhile now
I am going to replace as soon as I can
Old 07-25-2013, 12:37 PM
Grayson301's Avatar
Grayson301
Grayson301 is offline
Low/soft Pedal.. hydra boost systems
Doing a 2001 excursion ... aftermarket shows only one master cylinder.. motor craft shows two 1 with hyraboost BRMC26 and one with vacuum booster BRMC27. this is stroked differently .. try the correct master cylinder.
just found out the hard way
Old 07-17-2014, 12:19 PM
Mike F250's Avatar
Mike F250
Mike F250 is offline
Originally Posted by Deuce45
Well I've seen quite a few posts on this exact issue, however nothing gets posted after a fix or people simply don't fix it.
I can't live with *****ty brakes any longer so I'm ordering both the Hydroboost and the Master cylinder, I can get both for under $300 and it looks super easy to install. I'll post by the middle of next week on results here goes nothing ........
Not trying to bust anyone's *****. But I'm researching soft breaks and thinking it's a master cylinder. I see no fix reported
Old 07-17-2014, 03:58 PM
spongecop's Avatar
spongecop
spongecop is offline
Semper Fi
I was told by a member on here a while ago Ford had an issue with our master cylinders where the internal piston would over travel and force fluid past the cruise control cutoff sensor. Ford blamed the sensor for the fluid leak (and fires) but the real culprit was the MC. I have noticed on my truck the hotter the outside temps get the weaker the brakes and I get a progressively louder squeak/squish noise when the pedal is pressed. Hydroboost is also leaking a small amount.
So if the hydroboost only provides power brakes like a vacuum booster then the pressure and efficiency lies in the MC. If it is overtraveling causing leaks then maybe the pressures are off internally (+/-) causing poor performance. As soon as I have some money I am going to replace both units on my truck this summer.
Old 07-18-2014, 11:00 AM
05SuperFord's Avatar
05SuperFord
05SuperFord is offline
Ok i'm guessing no one has heard anything about this. I'll chime in because i am about to put my 3RD set of rear brake calipers on my truck in the past year. Not sure why i keep going through them but i have the same symptoms and then eventually one of them will start dragging followed by the other. Just wondering if maybe this problem is related to what you guys are having going on?
Old 07-21-2014, 07:45 AM
Mike F250's Avatar
Mike F250
Have you replaced the hoses? Not the lines, the hoses.
I'm happy to say mine was as simple as replacing the MC. I read through a few threads here on the brake issues and the one issue that couldn't get me past the MC is that with the truck not running, I could push the pedal slowly and it kept sinking.
Old 07-21-2014, 09:08 AM
05SuperFord
Yeah i just replaced the right rear hose on Saturday in the rain brakes felt good for 50 miles and now there back to being inconsistent
Old 09-06-2014, 10:02 PM
sgarder's Avatar
sgarder
sgarder is offline
Any update?
Old 05-28-2022, 06:34 PM
JahSoldier's Avatar
JahSoldier
JahSoldier is offline
1st Gear
Originally Posted by mueckster
The "compressed gas" label refers to the accumulator part of the hydro-boost. It provides limited power assist when the main pressure to the system fails. Air in hydraulic systems, either in the p/s or braking system can cause "sponginess". Brake fluid should be replaced at least every 2 yrs. Moisture is absorbed into the fluid and cannot be purged. The moisture in the system will release air into the fluid when it boils due to heat and pressure.
Well reading this, i believe that's what i just lost.. was turning and heard a pop, lost steering and brake assist. Having just lost and replaced my serpentine i knew that wasn't it. I looked through the driver wheel well and saw something. Reached in and pulled out a blue cylinder that said compressed gas. I'm assuming this was part of my hydroboost . Now i gotta look on how to replace that.
Old 05-29-2022, 07:10 AM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 2,969 Likes on 1,960 Posts
That blue cylinder is the accumulator. Hydroboosts can be rebuilt but you will need access to nitrogen to recharge the accumulator. I highly recommend evacuating the accumulator before recharging it so you don't have any residual moisture.
Old 05-29-2022, 07:34 AM
ESwift's Avatar
ESwift
ESwift is online now
cncfab
Received 1,626 Likes on 966 Posts
Great time to just replace with a new oem unit
https://smile.amazon.com/gp/aw/d/B00...?ie=UTF8&psc=1
The following users liked this post:
Old 05-29-2022, 09:20 AM
Lex2002's Avatar
Lex2002
Lex2002 is offline
If not a hard job. Enjoy.
  #28
Old 05-29-2022, 10:57 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Just go for the whole package!
Amazon Amazon
  #29
Old 05-29-2022, 11:26 AM
FordTruckNoob
Convert to electric brake booster. 😱
  #30
Old 05-29-2022, 12:29 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is online now
I didn't think you could recharge the accumulator? Has any buddy done this? Be nice if you could just change it out also. I loss my idler pulley once and use mine up also. Real shame to have to change out the whole hydraboost.
82fordowner
60
05-26-2015 07:30 AM
Bluethunder3320
04-01-2013 03:55 PM
7283-F250
General Automotive Discussion
06-12-2010 09:37 AM
mddibenedetto
04-14-2010 08:01 AM
classicfordluvr
10-05-2002 11:27 AM
Quick Reply: Hydroboost/Master Cylinder guidance
