Brake Problem
Old Apr 13, 2010 | 04:35 PM
mddibenedetto's Avatar
mddibenedetto
Brake Problem
Truck brakes fine for a little while. Maybe 10 mins of driving. Then the brakes (I'm pretty sure its the front brakes) start to lock up. Not completely, but enough to be very noticeable. The brakes were replaced (calipers and rotors) right before I bought the truck. The master cylinder is old and rusty, and I don't believe the truck has a brake booster, though I must admit, I don't know where to look. Though I would expect it to be near the master cylinder. Pedal is already fairly stiff (probably because it doesn't have a booster), but when brakes start to lock up, it becomes even stiffer.
Any ideas on what to look at or replace?
Old Apr 13, 2010 | 04:50 PM
freightshaker69's Avatar
freightshaker69
this happen to my friend the same thing happen we checked the fluid in the brake system found out that some jerk mixed power steering fluid in the master cil any way we drained all the fluid put the new stuff in worked find he bought this truck this way you might look at this the oil are differnt check this out its cheap to fix
Old Apr 13, 2010 | 05:31 PM
mddibenedetto
Will definantly check that out.
Old Apr 13, 2010 | 08:40 PM
4x4 Bart's Avatar
4x4 Bart
The brake booster would be mounted between the master cylinder and the firewall about the size and shape of a cake.
You need to determine if the its the front or rear. Try finding a gravel road, apply the brakes and see which wheels are dragging.
Old Apr 13, 2010 | 08:50 PM
jacfordf-250's Avatar
jacfordf-250
check the rubber lines they rot from inside out
Old Apr 13, 2010 | 08:57 PM
Nathan Plemons's Avatar
Nathan Plemons
I know you said you think it is the front brakes, so this may not apply, but I'll throw it out there just in case. I bought my truck and it was fine, but after driving it for a while the brakes got more and more touchy. They started locking up at the slightest touch. My problem was leaking wheel cylinders on the rear.
It caused the pedal to be really soft for the first depression, then if you pumped it, it would catch way up high and lock up nearly instantly. It seems that drum brakes don't like having fluid leaked onto the pads.
Might be worth checking out anyway. I found that I could get whole new cylinders for only slightly more than rebuild kits.
Old Apr 14, 2010 | 08:01 AM
mddibenedetto
Yeah, I do that. Though I'm almost positive it is the front due to the fact that that is where the burnt smell is coming from and the front are scorching hot compared to the rears. Makes me wonder if it might have to do with the proportioning vavle. uhhhg, makes me wish I had a better understanding of brakes in general.
BRONC-OH
Bronco II
Sep 4, 2012 08:40 PM
fwerring
Aug 31, 2010 03:52 PM
jaspirr
19
Mar 27, 2010 09:05 PM
ranger250Center
Feb 18, 2006 10:14 AM
heybrent
1978 - 1996 Big Bronco
Aug 31, 2002 06:59 PM
