I have an 09 4wd super duty with stock 265/70/17 tires. I want to go to a 305/70/17( E range of course) should this be a problem? the folks at tire kingdom and discount tire says although the tires will fit and not rub they will balloon out and only wear in the center. I have a friend that put 315/70/17 on his dodge and they look dam good, but he had to get the leveling blocks. I also am curious if there would be any problem pulling a 10,000 lbs tag along camper with this truck and the 305's? Any suggestions would be appreciated.
your rims are too narrow for a 315 width tire. they'll fit, but the narrow width will pull the outer edges of the tire upwards. hence why they said you'll wear in the centers mostly.
i have 305 buckshot mudders on my stock 7" wheels, have not had any uneven wear.. also have pulled my camper over a thousand miles on several occasions in the summer heat and never had any trouble with mine.. the are 8 ply tires with 50psi in them.. they seem to ride a little softer than the 10 ply tires
my local firestone guy (whom i trust and respect) urged me not to install lt325 65r18 detination a/t's on my 8" rims...recommended for 9-12" rims. i think the extra 2 inches overall diameter that i would get over my 275 70 18s would be worth a little extra wear but of course i would have to acknowledge the warranty would be voided since i need the E tow rating and do heavy miles, i'm torn...
