Transmission problem wont change into overdrive ?
HI Guys,
sorry for the delayed responce,
Transmission is not happy... it has damaged several parts and had a bearing chew out a support shaft.. The trans repair man did tell me all the things that require repair and i can get them if anyone would like to know ..
Short of it is he will be rebuilding the tranny with low stall modified converter and valve bodies ETC, ETC . all the thing i decribed before plus a few more
SSSimon,
the trans only had 100,000 km on it had done to good towing but not what i would call excessive
I have a temp guage incorporated with the Gryphon tuner so i monitor the tranny temp anyway
Thanks for all your thoughts I would of considred the JW trans but i need the truck back ..
SSSimon,
How'd Geoff go? Will we ever know?
Well I reckon he had to go the quickest route to a replacement trans - which was a local rebuild. I guess we won't hear anymore from Geoff while the rebuild holds up. I hope it does.
It's a tough call when you're depending on your truck for your living - quick local vs shipping time from the US.
