Sponsored by: Auxito
Overdrive problem
Old Jan 8, 2007 | 08:42 AM
2424dj's Avatar
2424dj
Overdrive problem
I have a 1999 f-150 that the light for the overdrive will blink like it is turned off, but it is not off. I have noticed that in the morning when it is cold it will shift from gear to gear slow. The overdrive is working but the light is still blinking. i would appreciate any input on where to start with this problem.
Old Jan 8, 2007 | 11:06 AM
Ratdawg's Avatar
Ratdawg
Try doing a search on earlier posts. I have a completely different problem with mine but when I was searching I found several posts that sound like what you're looking for. Apparently the overdrive light blinks as a code to indicate some kind of problem but I'm not sure exactly what it is.
Old Jan 8, 2007 | 11:43 AM
2424dj's Avatar
2424dj
Thanks, there are alot of postings when I do a search, so that should help me out.
Old Jan 12, 2007 | 12:34 AM
Chris 97 F150's Avatar
Chris 97 F150
your problem is gonna be the VSS (Vehicle Speed Sensor)...mine does that as well but mine is a 97 4.6L....theres one on the tailshaft of tranny and one on rear end...the speed sensors cause the speedometer to not work correctly or at all, causes the overdrive light to blink, and can also cause the ABS light to come on if one/they are faulty...id check them 1st
Old Jan 12, 2007 | 05:13 AM
2424dj's Avatar
2424dj
Thanks Chris, I will check into that this weekend and see what I come up with
campbell99
Oct 28, 2023 08:42 AM
BriR
18
Apr 16, 2021 09:08 PM
patsalters
Sep 11, 2013 09:43 AM
searsk
Nov 3, 2005 07:33 AM
aviatorone
Jan 29, 2005 09:23 AM
