I have a 1997 f250. When I turn off the overdrive the light on the shifter don't come on.Can it be the light or is there something else wrong? Can you change the bulbs in these things?
Thanks
ART
Ok I found what was wrong.The p.o. had cut all the wires to the switch.I'm going to buy a new switch.Anyone know how the switch comes out?I'm not sure if it just pushes in or what.
Thanks
ART
So be aware that with a new switch other problems may appear. Maybe the PO cut them to prevent the unit from being engaged or dis-engaged due to a problem in the transmission itself.
Thanks for the info.I got the switch out and it is good.One of the wire in the shifter was broke.I got them out but you can not pull them back thur.Looks like a dash mount is in order.
ART
