55 kept trying to start without key and now there's no power.
who checked your battery, and how did they do it? if it was the pimply faced kid at the auto store he might be clueless. I can't count the number of times I've heard people insist the battery was fine only to have it be badly discharged. Did you put it on the charger after the problem occurred? A bad ground connection can mimic a dead battery too. Are the terminals clean and where the battery cable attaches to the the truck's frame good?
Without my key I'n the truck I could push the starter button and it would crank the engine but not start it untill my key was In. So what I
think might have happend was the starter button was
stuck and it blew a fuse or a wire went bad from the consistent amps. But then the truck had no power after that, that's why I am confused. I even took the battery to get checked for amps and volts and they said it was good. So then I replaced the solonoid and still no power
Okay guys I got an update! So I hooked my battery back up and I turned my key an I had power! I even had power to my wipers and air conditioning which haven't worked I'n a while! So then I go to push the start button and I lose total power an I have to reconnect my hot wire to get the power to start again. What the heck?
Yep.. You definately have a short/grounding issue. Ensure that you have good engine to frame, and frame to body grounds. Not just some wimpy wire, but good cable sized stuff. Make sure the soleniod is mounted good and tight and that the mounting ear has good contact with metal.
Sounds like you probably have a 12V neg ground system, since you mention having A/C. Good grounds are key to having any electrical system reliable.
when that happens to me, its usually the main ground cable on the battery. Do you have any of those cheapy battery end clamps that have the bolt down crimp? if you do, throw that junk away! Oh i don't know how many times I have had to deal with those! I hate them! ok well maybe HATE is too strong, but...
Back to day one. You again had a good system until you engaged the starter. I think maybe either the wire between the solonoid and the starter maybe shorted to the frame,engine or starter case or the starter may have a internal short. Please don't install a new battery and attempt to start again without repairing the problem. chuck
This thread is becoming a good argument for a battery cut-out switch. I also noticed that in the '53-'55 stock wiring that there is no breaker or fuse between the hot power lead from the battery side of the solenoid all the way thru the amp meter, to the breaker on the back of the instrument cluster. And that breaker automatically resets on it's own. Finding some sort of fuse to put in that line close to the solenoid is on my long list of things to do.
this is just a symptom of the original problem, though. you started with a bad switch or a short somewhere related to that switch.
i'm betting you have the original problem plus everything caused by it.
I had my starter tested and it is good. I'm thinking it did that because the solenoid was arced. But I will check up on the cables
QUOTE=49fordpickumup;10829800]Back to day one. You again had a good system until you engaged the starter. I think maybe either the wire between the solonoid and the starter maybe shorted to the frame,engine or starter case or the starter may have a internal short. Please don't install a new battery and attempt to start again without repairing the problem. chuck[/QUOTE]
73-79owner
04-19-2006 10:22 PM
