1987 F-250 Lariat Issues
I'm having issues with the truck I just bought. One is stalling. 90% of the time, I cant come to a complete idoling stop without it stalling. Second is, today, I popped the hood and tried to check the oil and the entire metal tube that connects to the oil pan just came off. I'm not sure if it was welded and it just corroded or if it was some type of compression fitting that came loose. Some things I have done to the truck already are, replaced the water pump, fuel filter, spark plugs and wires, radiator hoses, and a basic service (oil change and other fluids, and filters). I guess I'm just looking for any suggestions from someone that knows more about these trucks then I do (which isn't much).
Need to run codes.
OBD1 Code Reader for $22.00
Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
I have no way to check anything, I only know the basics about my vehicles. When Something goes wrong, I have take it somewhere. I currently have no money for that so Im trying to figure it out myself. Basically, Its hard to keep the motor running in general. While I have my foot on the gas, its fine. But as soon as it comes down close to idol, most of the time it stalls. It also back fires sometimes. I have adjusted the idol up and down, I also took it too the shop I use and they checked to make sure there was nothing in the idol jets.
Thanks guys. Youve been helpful. I think I'm just going to take the carb off and have it rebuilt. I did however find a guy that may be willing to buy it if I fix the oil pan problem. With only 68k original miles and one owner, I'd prefer to hold on to it, but I just dont have the time to put into it. Thanks again.
ShastaLakeLndscaping
1997 - 2003 F150
24
11-26-2020 12:39 PM
cmcolfax
08-28-2009 08:08 PM
Cricket460
01-28-2003 06:09 AM
