Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 08-28-2011, 11:40 AM
gasserman56 gasserman56 is offline
1997 Ford F-250
gasserman56 is starting off with a positive reputation.
confused and needing help
Hey guys, I need help with my pick up. i have a 1997 F250 PSD 4x4 with an auto. My problem is with my trans, specificly the shift position switch. I have owned the truck only for a short period, I knew when I bought it it had a trans problem, would not shift gears. I ran the codes on it and got a P0708 code which is trans range sensor circuit high input. I was told this meant my shift position switch was bad. I called oriellys and had them order me one, when I went to pick it up it was different than the one on my truck, I had my old one with me and they started searching their computer for a match to it and it came back as a switch for a 1993 model truck. I had them go ahead and order it and I figured I would give it a try.... it did not fix my problem, so now I am starting to wonder if the original trans went out on the truck and instead of a rebuild the previous owner bought a used trans out of an older truck to replace it and when it would not work right decided to sale the truck.?.?. If anyone has a 1995-1997 F250 PSD with an E4OD trans in it that would not mind letting me take a look at it to see what the truck is suppose to have factory I would greatly appriciate you contacting me. I am in the Okla city area and would not mind traveling a little ways to look at one if i had to, or if anyone has any other ideas on this problem that may help too. Thanks a lot guys, looking forward to your responses.
  #2 (permalink)
Old 08-28-2011, 07:41 PM
jwtimme jwtimme is offline
Garage is empty, add now
jwtimme is starting off with a positive reputation.
have you tried posting this over in the tech section, there would be maby a few more sugesstions on what the problem is, I would let you look at mine but its a 2007
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
