1994 f-250 7.3 turbo misfire
Old 08-27-2011, 06:54 PM
idahodieselguy's Avatar
idahodieselguy
idahodieselguy is offline
A quick question that probably isn't so quick. My truck was running good and one morning when I got going and put a decent amount of acceleration it mad a slight knocking noise and went away. on the way home that evening it started misfiring i went and read some forum post and checked out a few things mainly making sure the valves were all tight and everything in the housing was ok. It was all good.
The most disconcerting thing was the glow plug under the turbo the wire had melted and the glow plug steam had broken off. I was wondering can a loose glow plug wire cause a misfire and if not i need some more ideas. I am taking one of the injectors in to be tested to make sure it isn't that. Any help would be appreciated.
Old 08-27-2011, 07:04 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
You will get so much heat for this statement LOL.....No this is not your problem. the glow plugs are only active when starting.
You have to take all 8 to be tested not just one. that one could be good but the other 7 could be bad. i would be willing to bet that you have at least one bad injector.
How many miles on IP and injectors? if you are over 100,000 it is time to start shopping for new IP and injectors.
Old 08-27-2011, 07:12 PM
idahodieselguy
I figured as much felt sort of dumb asking but had to get it out of my head with an answer.
My truck has 208000 on it and i purchased the truck six months ago. So im not sure when they were replaced last.
Old 08-27-2011, 07:20 PM
bashby's Avatar
bashby
bashby is offline
Sounds like an injector is bad. If you get a 5/8 wrench and crack the line loose to each injector, one at a time, it will cause that cylinder to misfire. The one that doesnt change the way the motor runs is the bad cylinder. You could then swap the injector with one from a cylinder that is firing, and if your miss moves to the other cylinder you know its the injector.
Old 08-27-2011, 07:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
you can't just test one injector.the bad one could be anywhere.
next time she knocks,pull over pop the hood,and quickly touch each steel injector line.
find one much hotter than the other,and you've found your bad/knocking injector.
heck,don't even wait for the knock.just check 'em once she warmed up after a 10 minute drive,and if no luck try when she knocks.
i was gunna add the info above as another way to test.follow bashby's advice also if no luck with finding a hot line.
another way,is to use a large screwdriver.place the flat metal end on the injector and place your ear on the handle.a good injector has a very loud distinct CLICK! to it.find one that sounds much lower and you've found a failing injector.find one that doesn't click at all and you've found a dead one.
Old 08-27-2011, 07:28 PM
idahodieselguy
so injectors can knock as well as the cylinder.
Old 08-27-2011, 07:30 PM
bashby's Avatar
bashby
bashby is offline
Yes, "injector knock" is a common term in the diesel world.
Old 08-27-2011, 07:31 PM
'94IDITurbo7.3
they cause the knock.
Old 08-27-2011, 07:32 PM
FORDF250HDXLT
yeah no doubt.
so loud of a knock,you'd swear something was seriously wrong with your engine if you didn't know the sound.it's god awful really.
Old 08-27-2011, 07:33 PM
idahodieselguy
Thanks for the info. This is my first diesel and learning as i go thanks for the help.
Old 08-27-2011, 07:40 PM
'94IDITurbo7.3
Originally Posted by FORDF250HDXLT
yeah no doubt.
That's how it was for me when i had 4 bad injectors.
Old 08-27-2011, 07:45 PM
idahodieselguy
yea the sound scared the crap out of me
Old 08-27-2011, 07:48 PM
'94IDITurbo7.3
ya it sounds like rod knock and that=really bad.
grobe0ba
16
03-31-2012 08:36 PM
Visseroth
07-23-2011 07:05 PM
WA.Ranger
22
03-15-2009 09:27 AM
rigoberto
12-16-2008 10:02 PM
TJC
04-18-2007 09:55 PM
Quick Reply: 1994 f-250 7.3 turbo misfire
