overheating
Old 08-08-2011, 05:53 PM
jbodin18's Avatar
jbodin18
jbodin18 is offline
overheating
my 6.0 overheated this weekend and blew about 3 gal out the overflow bottle before I was able to stop and refill. EGR is dry, all tests passed at dealership. They think the edge evolution is bad. I run it in stock mode and was using only for gauges. The previous owner said he used for tow mode. They think it is causing the fan to not kick on properly.
What do you all suggest? I'm happy with ripping the thing out and just using scangauge. What will it take? Any suggestions on what might really be wrong?
I'm going to disconnect from the computer tonight and see what happens.
Old 08-08-2011, 07:47 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Something caused your degas to puke. I call BS on the bad tuner. Unless they are willing too say headgaskets too.
Old 08-08-2011, 09:08 PM
jimh425's Avatar
jimh425
jimh425 is offline
I've heard of the same issue without a tuner. I'd be interested to find out what "all" of the possibilities are.
Old 08-08-2011, 10:07 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
use the SGII to watch the FAN RPMs
at 216 fWT[or ECT] mine fan rpm really picks up to like 800 rpm and up
even ambeint temp plays into the fan speed
hows your ECT vs EOT spread
Id watch all I could with the SGII
Old 08-08-2011, 10:20 PM
bismic's Avatar
bismic
bismic is online now
Received 2,494 Likes on 1,731 Posts
What year model?
Do you have an EGR delete?
Old 08-08-2011, 10:48 PM
BLADE35's Avatar
BLADE35
X2 here on the tunner being bad causing your issues
could be as simple as a bad thermistate to
post up your numbers with SGII and the other info
Old 08-08-2011, 10:50 PM
jbodin18's Avatar
jbodin18
jbodin18 is offline
06 no egr delete. I have been watching ect and eot with my evo and delta typically less than 10. Ect jumped all over though. Climbed to 255 then back down to 220. I believe fan is kicking up at the 215 range. Not real sure what to think. If I try unplugging evo from obd ports should computers go back to normal or do I need to pull whole thing out and does the computer need reset?
Old 08-08-2011, 11:05 PM
BLADE35's Avatar
BLADE35
any coolant puke
start with the easy like a new thermistate
watch the fan rpm with the SGII make shure its coming on
Old 08-08-2011, 11:12 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
He was 3 gallons low I don't think this of asimple fix
Old 08-08-2011, 11:16 PM
BLADE35's Avatar
BLADE35
my bad I didnt read the first post very well thanks Jim
Old 08-08-2011, 11:19 PM
BLADE35's Avatar
BLADE35
hope it aint head gaskets
does it have headstuds?? since it tows tunned
Old 08-08-2011, 11:24 PM
jbodin18's Avatar
jbodin18
jbodin18 is offline
No headstuds.
Old 08-08-2011, 11:27 PM
BLADE35's Avatar
BLADE35
do you know if they did a cylinder compression test
Old 08-08-2011, 11:47 PM
jbodin18's Avatar
jbodin18
jbodin18 is offline
I don't know. I guess that would test the gasket?
Old 08-09-2011, 10:10 AM
BLADE35's Avatar
BLADE35
Yes gaskets heads piston rings ect...
Quick Reply: overheating
