overheating
Old Aug 8, 2011 | 05:53 PM
jbodin18's Avatar
jbodin18
overheating
my 6.0 overheated this weekend and blew about 3 gal out the overflow bottle before I was able to stop and refill. EGR is dry, all tests passed at dealership. They think the edge evolution is bad. I run it in stock mode and was using only for gauges. The previous owner said he used for tow mode. They think it is causing the fan to not kick on properly.
What do you all suggest? I'm happy with ripping the thing out and just using scangauge. What will it take? Any suggestions on what might really be wrong?
I'm going to disconnect from the computer tonight and see what happens.
Old Aug 8, 2011 | 07:47 PM
Unrealo4's Avatar
Unrealo4
Something caused your degas to puke. I call BS on the bad tuner. Unless they are willing too say headgaskets too.
Old Aug 8, 2011 | 09:08 PM
jimh425's Avatar
jimh425
I've heard of the same issue without a tuner. I'd be interested to find out what "all" of the possibilities are.
Old Aug 8, 2011 | 10:07 PM
BLADE35's Avatar
BLADE35
use the SGII to watch the FAN RPMs
at 216 fWT[or ECT] mine fan rpm really picks up to like 800 rpm and up
even ambeint temp plays into the fan speed
hows your ECT vs EOT spread
Id watch all I could with the SGII
Old Aug 8, 2011 | 10:20 PM
bismic's Avatar
bismic
What year model?
Do you have an EGR delete?
Old Aug 8, 2011 | 10:48 PM
BLADE35's Avatar
BLADE35
X2 here on the tunner being bad causing your issues
could be as simple as a bad thermistate to
post up your numbers with SGII and the other info
Old Aug 8, 2011 | 10:50 PM
jbodin18's Avatar
jbodin18
06 no egr delete. I have been watching ect and eot with my evo and delta typically less than 10. Ect jumped all over though. Climbed to 255 then back down to 220. I believe fan is kicking up at the 215 range. Not real sure what to think. If I try unplugging evo from obd ports should computers go back to normal or do I need to pull whole thing out and does the computer need reset?
Old Aug 8, 2011 | 11:05 PM
BLADE35's Avatar
BLADE35
any coolant puke
start with the easy like a new thermistate
watch the fan rpm with the SGII make shure its coming on
Old Aug 8, 2011 | 11:12 PM
Unrealo4's Avatar
Unrealo4
He was 3 gallons low I don't think this of asimple fix
Old Aug 8, 2011 | 11:16 PM
BLADE35's Avatar
BLADE35
my bad I didnt read the first post very well thanks Jim
Old Aug 8, 2011 | 11:19 PM
BLADE35's Avatar
BLADE35
hope it aint head gaskets
does it have headstuds?? since it tows tunned
Old Aug 8, 2011 | 11:24 PM
jbodin18's Avatar
jbodin18
No headstuds.
Old Aug 8, 2011 | 11:27 PM
BLADE35's Avatar
BLADE35
do you know if they did a cylinder compression test
Old Aug 8, 2011 | 11:47 PM
jbodin18's Avatar
jbodin18
I don't know. I guess that would test the gasket?
Old Aug 9, 2011 | 10:10 AM
BLADE35's Avatar
BLADE35
Yes gaskets heads piston rings ect...
