my 6.0 overheated this weekend and blew about 3 gal out the overflow bottle before I was able to stop and refill. EGR is dry, all tests passed at dealership. They think the edge evolution is bad. I run it in stock mode and was using only for gauges. The previous owner said he used for tow mode. They think it is causing the fan to not kick on properly.
What do you all suggest? I'm happy with ripping the thing out and just using scangauge. What will it take? Any suggestions on what might really be wrong?
I'm going to disconnect from the computer tonight and see what happens.
06 no egr delete. I have been watching ect and eot with my evo and delta typically less than 10. Ect jumped all over though. Climbed to 255 then back down to 220. I believe fan is kicking up at the 215 range. Not real sure what to think. If I try unplugging evo from obd ports should computers go back to normal or do I need to pull whole thing out and does the computer need reset?
