Vibration in 3rd Gear
So a little O/T, but mine is more of a delayed shift from 2nd to 3rd.. and if im really hammering it...it delays MORE and then SLAMS into 3rd.
What would that be then?
My friends are saying that my 3rd gear must have a few missing teeth and finally when it catches thats the big slam, but why would it take so long for it to actually shift from second to third? Like you can feel it disengage at 25 or so and it hits at 30..or 35-40 if hammering it...
Yet it drives fine if im not hammering it.. so im babying it until I can afford to fix..or figure it out/replace.
on
1 Post
The reason it shifts hard when accelerating hard is that the torque converter is slipping more. If you accelerate lightly it might be slipping 100 RPM but it will slip 500 RPM or more when you're at full throttle.
First, "gears" don't slip when they are missing a tooth. They will bang and pound and fail REALLY fast.
Second, 3rd gear is direct. In this case there is no relative motion between any gear in the transmission.
If that's the only sign of trouble then stop worrying about your transmission.
Thejudge
1999 to 2016 Super Duty
06-28-2018 04:25 PM
