Driving by Vacuum?
Just 1 to 3 inches vacuum change does make a diffrence in MPG. That's something you will not feel but able to see with the vac guage. I have them in my 89 F250 and my vacuumless(no wonder why a 460 gives crap mpg) 95 E350. Now on my E350 when BOTH AC compressers are running the vac will drop 2" but I don't feel anything loading the engine.
If you have a carb with a power valve, a vacuum gauge could be handy to have for MPG purposes. It's simple: the more throttle, the less manifold vacuum. This is where it pays to know which power valve is installed and it's opening point. For example, if you have a 6.5 power valve and the manifold vacuum drops below that figure, the PV will open up and allow more fuel to be used. Keep it above the opening point and you will burn less fuel.
If easy to hook up, I think it would be nice to be able to see the vacuum all the time. Aside from mpg considerations, it would be a nice "tuning monitor" - when you are at idle you can see that it is steady at 18 mm Hg or so, and if it isn't steady that would indicate something may be wrong.
treverd
01-22-2016 02:39 PM
jsutton
06-26-2008 08:25 AM
Big_Man_Brad
02-21-2008 05:57 PM
