5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Ping
Old 06-12-2012, 08:18 PM
Butl85's Avatar
Butl85
Butl85 is offline
Ping
Was wondering if anyone else experiences this. Under about 1/4 to half throttle(down just below the point of shifting up a gear) I hear a rattle/ping. Does not do it under higher RPMs when you are getting on it more. Also it is only for a second, its almost like the computer does not have time to adjust to throttle and pings for a second until the computer/tune/cam(whatever is causing it) has time to correct it.
I know the obvious answer is take it into the dealer because it has a warranty. But I leave in less than two weeks on a 3800 mile trip and do not want to put that in jeopardy. Just wanting to know if this is normal for all of these motors or is it something I need to get looked at.
Old 09-23-2012, 11:44 PM
jonbar87's Avatar
jonbar87
jonbar87 is offline
5.0L? If so, I experienced bad ping pulling a 3500lb pontoon at about 3/4 throttle around 3 - 4k rpm. It was very bad.
troverman
6.2L V8
35
03-25-2014 08:29 PM
lexustbs
6.7L Power Stroke Diesel
13
03-01-2011 10:34 PM
duggae
1983 - 2012 Ranger & B-Series
12-27-2005 11:45 AM
Ford-man22
2004 - 2008 F150
04-22-2005 09:44 PM
ejpreston
2004 - 2008 F150
09-16-2004 02:02 PM
Quick Reply: Ping
