hey guys ive been retrofitting a 76 f350 w/o AC to have on-board-air ford air tools airing up tires ect. i mounted the compressor brakets pullys and compresor, and now my power steering pully doesnt line up with the crank and waterpump pulley........the p/s pump is too far back and is squiling the belt. can the p/s pullet be adjusted or do i need to shim the p/s braket ?
ok il get some tomorow the crank and p/s pulleys are square with each other but the p/s is 1/4-1/2 inch behinde the crank and its makeing the belts squeek
ok il have to go back to the pull-apart and get the p/s pulley how is the pulley fastend to the pump is it pressed on? what do i need to take with me? or is it posible to rig/ adjust the pulley i have to make it work?
The pulley will be pressed on. You'll need a puller like this to remove the pulley. Relatively easy to remove with the right puller. Whatever you do, DON'T use a regular 2 or 3 jaw puller. These will destroy the pulley.
