Belt routing question
Old Jan 27, 2014 | 06:45 AM
trilogymac's Avatar
trilogymac
Good morning.
I have a 1977 highboy with a 351M. I have installed a Nostalgic Air AC. The belts are currently:
inside belt-Alternator, waterpump and crank
outside belt-A/C, idler, crank
I am installing PS using a Saginaw pump and want to know if there is any reason I shouldn't use the AC, idler, crank loop for the alternator and put the PS pump on a loop by itself. This is the easiest way for everything to line up. The compressor is a Sanden.
Thanks,
Trilogymac
Bill
Old Jan 27, 2014 | 07:25 AM
User 71024's Avatar
User 71024
Originally Posted by trilogymac
Good morning.
Thanks,
Trilogymac
Bill
Your best bet would be to add a sheeve to the crank or see if you can find a double sheeve setup for the alt / AC.
Old Jan 27, 2014 | 07:38 AM
User 71024's Avatar
User 71024
I just checked my garage, I am about 99% sure I took this off a 79 f-150 with a 400, your welcome to it if you pay the shipping. It's got 3 good sheeves and one small one for a smog pump.
OK, I couldn't figure out how to add a pic so I will add them to my garage. Give me a minute or 2.
Old Jan 27, 2014 | 05:35 PM
trilogymac's Avatar
trilogymac
Eric,
Good evening.
Thanks for the reply. I checked in the parts that the PO gave me with the truck. There was a 3V crank pulley and the correct smaller WP pulley. I put them on earlier this afternoon and EVERYTHING lined right up. The alt is on a crank pulley by itself, the AC is on a crank pulley with an idler and the PS pump is on the crank and WP. All I need are 2 new belts and I'm in high cotton.
Thanks for pointing me in the right direction.
Trilogymac
Old Jan 27, 2014 | 06:57 PM
User 71024's Avatar
User 71024
happy I could help.
Holehawgg
Mar 15, 2014 09:44 PM
coz
Aug 16, 2010 11:45 AM
pit_of_pity
Jun 6, 2010 12:41 PM
