Shifting from park
Old 03-31-2003, 11:31 AM
deano512's Avatar
deano512
deano512 is offline
Shifting from park
I have a 01 F350 PSD 4WD with an E4OD Tranny.
Lately, to get the truck out of Park, I have to push the brake pedal much harder, and sometimes I have to pump the brake pedal, to get it to come out of park.
Any Ideas on what could cause this? Is there a Switch on the brake pedal that may need "calibration"??? Can I Defeat this feature???
Thanks for any help
Deano
Old 03-31-2003, 08:23 PM
Fordnite302's Avatar
Fordnite302
Fordnite302 is offline
Shifting from park
there should be a sensor on your brake pedal that senses when the pedal moves ( also turns on brake lights) on your vehicle this sensor not working would make it unable for you to shift since it doesnt sense that the pedal has been depressed. maybe the connection is bad. my guess would be the sensor, good luck.
Old 04-01-2003, 10:21 AM
deano512's Avatar
deano512
deano512 is offline
Shifting from park
Can this be vacuum controlled vice an electric switch???
Deano
Old 04-01-2003, 02:58 PM
Fordnite302
Shifting from park
no it should not be vaccum contolled it is a mear sensor that plugs into the side of the pedal support.
deano12313
07-29-2011 10:53 PM
deano-was-his-name-o
06-21-2010 12:04 PM
17
03-26-2009 12:58 PM
deano77691
21
08-21-2007 09:56 AM
deano77691
18
07-30-2007 10:42 PM
Quick Reply: Shifting from park
