Battery Light problem
Old 07-18-2011, 08:37 PM
AlexHoc10's Avatar
AlexHoc10
AlexHoc10 is offline
Hey guys I have a 2003 f-350 super duty 6.0L. Recently the battery has been coming on, I put a new pig tail on (the one on top on the alternator), that did not help so I put a new alternator in. The light stayed off for a day or so then kept coming on again, if I would jiggle the pig tail the light would turn off. But now no matter what I do the light still stays on. Sorry please help me.
Thanks
Old 07-18-2011, 09:11 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Have your batteries load tested. If they are failing they will take a new alternator out very quickly but may still start your truck.
IMHO--your "new" alternator is still bad if the "I" circuit is good. What brand did you use?
Old 07-18-2011, 09:16 PM
AlexHoc10's Avatar
AlexHoc10
I bought the autozone brand, and when the alternator worked i had the batteries tested and they said they were fine.
Old 07-18-2011, 09:18 PM
npccpartsman
Have you tested the voltage with a meter and truck running? A battery light means it's not charging. Either the "I" ciruit that goes from the alternator to the dash cluster is bad, the dash cluster is bad, or the alternator is bad. Even "new" parts can be bad.
Old 07-18-2011, 09:21 PM
AlexHoc10's Avatar
AlexHoc10
Yea i tested the batteries when the truck was running and the voltage was dropping. I m gonna end up just taking it to ford cause i cant figure it out
Old 07-18-2011, 09:29 PM
npccpartsman
Did you have the new alternator tested at someplace different than Vatozone??? It's possibly just a bad "new" piece.
techno101
1999 to 2016 Super Duty
01-17-2015 09:48 PM
Calheader
11-19-2014 02:30 PM
koski19
04-08-2013 11:19 AM
00excursion0
09-27-2012 06:46 PM
LonelyRoad2004
Electrical Systems/Wiring
05-20-2004 10:05 AM
Quick Reply: Battery Light problem
