Sponsored by: Real Truck
Battery trouble!!!
Old Jan 11, 2015 | 11:49 AM
techno101's Avatar
techno101
Battery trouble!!!
Ok here goes:
Everything was fine a few weeks ago until I tried to jump start a backhoe. On the way home, the gauges go crazy, and go out. Battery light came on. Figured alt. went bad. Put on a new alt. and everything was good for a week, then battery light came on again. Tested alt. at Oreillys and voltage reg. was bad. Changed alt again, battery light on and off still. Turned out the alt. connector pig tail need changing, cut off old one and spliced on new one. No more battery light. 3 days later, batteries were really low, had to jump start. Then the same at lunch time. So, bought 2 new batteries, installed, everything is good. Went home Friday, go to start truck Sunday morning, and nothing. No door locks, no interior lights, no nothing, key code not working, nothing....
Someone please help, I can't keep putting $ in this truck
Old Jan 11, 2015 | 11:56 AM
avaautotech's Avatar
avaautotech
Get the batteries load tested in the truck. Separate one battery and load test the cables going to the still hooked up battery. Test wiring to alternator and test it with truck running.
Old Jan 11, 2015 | 12:19 PM
techno101's Avatar
techno101
According to Oreillys, alternator tested fine, and the batteries were brand new 3 days ago, and the truck hasn't been cranked.
Old Jan 11, 2015 | 02:12 PM
Lou Braun's Avatar
Lou Braun
This sounds like a bad connection between the batteries and your truck's electrical system. A crummy, high resistance, connection will give you this sort of problem.
Recommend removing and cleaning each battery connector and any other large connectors that show any evidence of corrosion. Pay particular attention to the area where you hooked the jumper cables to in the attempt to start the hoe.
Lou Braun
Old Jan 11, 2015 | 03:09 PM
techno101's Avatar
techno101
All battery terminals and connectors are clean, I keep them sprayed with the red corrosion protectant.
Old Jan 11, 2015 | 03:10 PM
techno101's Avatar
techno101
Also, what relays are directly linked to this system? Could it be one is stuck open or closed? Causing a voltage draw when the engine is off?
Old Jan 17, 2015 | 09:48 PM
somehowford's Avatar
somehowford
Did you figure it out? If your batts and alt all test okay, then you are on the right track with an amperage draw. Here is how to check.
Remove negative battery cables. Take a volt meter that can measure amps and place it in-line on one of the batts so that all current is passing through the meter. (Black lead to cable, red lead to batt post) Most meters have a fuse for amp mode, so don't turn the key on or it will draw too many Amps. If it reads even 0.25 Amps this is enough to discharged batteries in just a few days. If it reads amps then pull fuses one at a time till you find the one that is drawing. Go in the owners manual and see what componants are on the fuse that's drawing. Hope you have already figured it out, but if not good luck!
66with352
1997 - 2003 F150
Aug 11, 2024 10:42 PM
Tanner2255
13
Jan 21, 2014 10:42 AM
Scoob5555
Dec 12, 2012 01:29 AM
handyandy123
Oct 10, 2012 09:36 AM
Mark White Sr.
Oct 13, 2010 02:48 PM
