rocker arm assembly rebuild ..help!
so i tore down my tbird 390 rocker assemblies , wow were they gooped up , i found one surprise a broken spacer spring . i founda guy on ebay selling new ones so i ordered one.
here's where i need help i removed the end plugs on the shafts for cleaning , used the sheet metal screw and thick washer method . then pushed the other side out with a long 3/8 rod . so i need to find 2 end plugs anyone know where to get these ?
here's some pics
before
after
here's some pics
before
after
Dorman #P7C.
NAPA part # CEP 2192098
Original Ford # EAA-6572-A
Not sure the NAPA # is still good but maybe?? You'd have to check and the Dorman # should be correct. I'm also not sure if the Ford and aftermaket Sealed Power shafts use the same plugs. For such a simple plug it can be a real pia to find the right ones. Let us know how you make out and what you use. Good info for the future.
MIKES 68 F100
248
05-22-2016 06:19 PM
MIKES 68 F100
77
12-30-2015 01:19 PM
MIKES 68 F100
30
11-18-2015 07:40 AM
