9" and front Discs rebuild
last week i stripped a 77 F150 of the Front Disc brakes and the 9" rear end to rebuild for Pebbles .
I will be doing the cleaning and painting of both at the same time .Then rebuilding the 9" new bearings, 3.50 gears,mini spool ,new brakes then i will dive into the Front all new everything .
here's the pics
donor truck 77 F150 302 auto 2.75 gears
front end Disc to Disc removed
The score in my garage waiting to be taken apart
here's the pics
A mini-spool will be fine if you plan to spend a lot of time at the dragstrip (straight line driving) otherwise, I think it's a mistake. A factory type Traction-Lok differential isn't very expensive and will respond well to any type of driving, particularly when it involves turns.
http://m.ebay.com/itm/9-Inch-Ford-28-Spline-Posi-Unit-Trac-Lok-Loc-Traction-Lock-9-Inch-NEW-/221914754655?nav=SEARCH
....but, not my truck or my call to make on that.
.....the Dentside donor truck front bumper in your photograph.... I've been wondering about this. Was '78 the first year the oval opening (in the license plate area) was stamped into the Dentside front bumpers?
You had posted a photograph of the 3rd member tag. It had a September assembly date on it. If the truck was built around September, 1977, wouldn't it have been titled as a '78 model?
You had a photograph of the warranty tag too. On it was stamped "1978" at the middle, bottom portion of the tag.
It may not make much if any difference if the truck is a '77 or a '78 but with these three things, it makes me wonder if the donor truck is actually a '78 instead of a '77?
[QUOTE=HIO Silver;15858510]Well yeah, D5 is before 1977.
If Mike's donor is in fact a 1978 as you had postulated above, then it **might* have a D8TA casting.... that's all I was eluding to. Dig??[/QUOTE
I wasn't implying anything wrong with what you said. I was just giving out what's on my '77 beam.
If Mike's has a D8 casting, maybe it's a '78. If it has a D5 casting, maybe it's a '77.
My guess is there was an I-beam casting change in '73, '75 and '78.
I could see where there would have been a change in the '75 beams from the '73/'74 (longer kingpins than previous years). I don't know what would have been different between the D5 and the D8 casting or where within the model year the changes took place.
Mike... I believe we are suggesting you reconsider that mini-spool.
