Need 48-50 f-1 cab
I, too, had a 51-52 cab and couldn't give it away. I ended up cutting the roof off and scrapping the rest.
What part of your roof is dented? Have you thought sectioning the roof with another roof from a different cab? Like I mentioned, I have the top portion of the cab from a 51-52. However, the roof itself is the same as 48-50 as long as you section it at the roof seam.
My 50 had a huge dent in the back corner of the cab roof. It looked like somebody dropped some big lumber on it. Go to the auto parts store and buy yourself a hammer and dolly. I was able to straighten it completely. You have nothing to lose. Sheet metal like that seems to want to return to its original shape.
True, but like I said, what do you have to lose? You can't mess it up any further, and you might not find a suitable replacement either. Plus you could get it to where it only needs 50 pounds of bondo to fix it back. Why don't you post a picture of the dent? There are some very talented people on this board who might be able to help.
old_dan's cab also had a tree branch fall on it in towards the back. The roof was creased. You should see his cab now. I set him up with a body shop to do some work in trade for parts that he had. They did an amazing job. Now, can't even tell that a tree fell on the roof.
Old metal is not the same as new metal. It's thicker and stronger. With some heat and hammer/dolly work you may be able to return the roof into the correct shape.
Post some pictures so we can see.
