Help = 2.3 1997 Ranger Timing marks???? Help
Old 07-05-2011, 06:26 PM
Broncoholic1's Avatar
Broncoholic1
Broncoholic1 is offline
Got the new belt & tension-er in today & looking for the timing marks to line up right ?
Turns out it was built in 8/96 so a 97 truck.
Crank is TDC went around the sprockets counter clockwise & turned it over 2 times all lined up.
THe marks line up on the balancer, @ TDC with the cam & oil pump lined up/
It starts hard & runs ruff. smells like raw fuel. CHuggs like a Diesel
Old 07-05-2011, 10:10 PM
FireMe's Avatar
FireMe
FireMe is offline
No triangles, should be a small dot on the front face of one of the cam sprocket teeth, to be lined up with the pointer. Crank sprocket keyway gets set to 12 o'clock. Rotate crank two turns and recheck alignment.
Old 07-05-2011, 10:37 PM
Broncoholic1
All there was are a notch on the outer ring on the cam sprocket, & a triangle on the rear belt housing case, same with the oil pump drive only it was a diamond.
The crank was set at 12:00 position the timing mark lines up at TDC with the cover on it.
Started it up & it is chugging, think it is off 10*
Old 07-06-2011, 09:48 PM
Broncoholic1
Went old school om it the marks got worn off some hard to see
We went with the cam Keyway at 6:00
the crank keyway @ 12:00 & the oil pump drive @ 6:00
Runs like a champ
ClintonA
12-18-2016 10:05 PM
free59mod
11-23-2015 10:29 PM
Cbad285
11-18-2015 09:18 PM
DPDISXR4Ti
08-31-2012 07:23 PM
Jim88554
1997 - 2003 F150
11-17-2008 05:39 AM
Quick Reply: Help = 2.3 1997 Ranger Timing marks???? Help
