1985 Bronco Timing Gear
Old Dec 16, 2016 | 07:39 PM
ClintonA's Avatar
ClintonA
1985 Bronco Full-Size 5.0L EFI
My timing gear on my cam stripped out, I broke it all down and went to replace it. While all the work I was doing I didn't check to see if it was TDC before I put the gears on, I had it all together when I started to doubt I remembered to check the actual TDC. I did line up the TDC marks on the gears. Finished putting it all back together and it wont start. Turns over fine, doesn't sound like any back pressure from valves being closed at the wrong times. Is it possible I have the cam gear 180 degrees off or can it not do that if you like the marks up. Want to know if I should break back into it any redo my mess.
Side note, got a new distributor for it. It came with a black TFI unit. I also have a working gray one and decided to try it in my efforts to make the truck work but made no difference. Should I leave the black one in or change it for the gray?
Thanks for reading!
Old Dec 17, 2016 | 02:12 AM
matthewq4b's Avatar
matthewq4b
Thanks for reading!
If the marks on the gears were lined up you are good to go. But the distributor may be 180° out. You may have to pull the distributor and reinstall in the correct position.
Make sure the engine is TDC on the compression stroke for Cyl#1 lift the distributor cap & insure that the rotor in the distributor is pointing to Cyl #1 on the cap. If it is not you will have to pull the distributor rotate it 180° and reinstall then reset set the base timing. That is the first thing I would check
Old Dec 17, 2016 | 06:59 AM
Franklin2's Avatar
Franklin2
To make sure #1 is at TDC, pull the sparkplug out on #1 and turn the engine over by hand till you feel pressure when you plug the sparkplug hole with your finger. When you feel pressure, keep turning till the marks line up on the timing pointer.
Old Dec 17, 2016 | 10:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's certainly possible to install a timing set with the cam out of sync but there is no 'compression' or 'exhaust' stroke of the crank, so as long as the keyways and dots line up it's good.
I am pretty sure that gray denotes "push start" tfi and black is "computer controlled dwell", but i am not an eec IV expert.
If you have the little extended screwdriver it might be wise to try swapping modules.
Old Dec 18, 2016 | 07:02 PM
ClintonA's Avatar
ClintonA
Thanks for the replies, I will make absolutely sure to check TDC from #1s spark plug hole and see where it lines up.
Thanks for the information! Was trying to figure out the difference. I ended up with this distributor because I had to order one with a cast iron gear to match the one that was in there originally. It came with a black TFI unit which I did change out to the gray. Since it started with the black unit does the pickup inside care about the change? The crank and the cam gear lines were perfectly lined up. Also does it matter if the original cam timing gear was aluminum and the new is cast iron?
Also there is more to the story that might help- One day I started it and drove it 20 miles to a shopping center, parked it, ate lunch, came back and I started it then put it into reverse and it died as soon as it went into gear. Now this motor had tons of neglect from the first owner, I timed it maybe like a few weeks before this happened and it was running amazingly better. The timing chain was very worn out.
Old Dec 18, 2016 | 10:05 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
As I said, I'm no expert but I do not notice a physical difference in the pip (profile ignition pickup)
I have read that some rotors are different, but again I do not know the specifics.
So i am going to defer to others on this forum that know a lot more details and nuances about your ignition than me.
backbonejay
Apr 12, 2013 04:31 PM
rostronic
Mar 6, 2012 10:17 PM
Mestrell
23
Apr 8, 2006 09:09 PM
mayhem
Aug 17, 2004 12:55 PM
tz750a
Jul 6, 2004 09:37 PM
