93 F150 Running WAY TOO rich
Old 07-04-2011, 11:32 PM
BigJared's Avatar
BigJared
BigJared is offline
Working on a 93 F150 2wd. Had bad motor. We replaced it with a 5.0 from a 94 Mustang Gt. engine has an E303 cam, full length headers, 2.5 inch pipe off of headers into custom y pipe into single 3 inch in and out flowmaster, no cats, new O2 sensor. starts easy. idles fair. sounds EXCELENT. it fouls plugs in less than 5 gallons of fuel during testing and idleing in the driveway. you can see it and you can smell it in the exhaust. it is bad.
anyone let me know. I understand this is a bit much cam for speed density, but I would think it would be too lean, not too rich.
Peace.
Old 07-05-2011, 07:35 AM
BigJared's Avatar
BigJared
BigJared is offline
please help anyone....
peace
Old 07-05-2011, 08:02 AM
Conanski's Avatar
Conanski
Conanski is online now
Are there any codes and is the fuel pressure within spec? That cam is not at all compatable with the EFI system in that truck so it will have to go if you want decent drivability from this.
Old 07-05-2011, 10:23 PM
BigJared's Avatar
BigJared
BigJared is offline
Thanks.
No codes.
Haven't checked the fuel pressure yet.
I understand there will be a slight driveability issue, but I have seen the combo work in S/D Mustangs. I should be able to check the fuel presure tomorrow.
Do you know if the 93's were "batch fire" or "sequential port" on the fuel injectors? we had this combo in an 86 F150 with stock "batch fire" ecm and it ran fine with the stock cam versus the E-cam. I had rewired the injector harness to "batch fire" properly with the HO-302 firing order versus the standard truck firing order. I have not rewired the 93 injector harness.
Thanks again.
Old 07-07-2011, 10:03 PM
mr.fordneck's Avatar
mr.fordneck
mr.fordneck is offline
my 90' was running too ruch. A new wiring harness fixed it
Old 07-08-2011, 06:53 AM
CS45's Avatar
CS45
CS45 is offline
When my F250 5.8 was running rich it was caused by exhaust leaks before the O2 sensor. Fixed that with a complete new exhaust and no leaks, not running rich, no CEL.
CS45
Old 07-08-2011, 07:05 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Have you checked the fuel pressure regulator for signs of leaking? Pull the vacuum line off of it, visually inspect and smell it for signs of fuel. Very common problem to have a leaky FPR diaphragm.
The '93 trucks were all batch fire BTW.
Old 07-08-2011, 07:27 PM
BigJared's Avatar
BigJared
BigJared is offline
Thanks everyone. I hope to be able to try and check all of that tomorrow.
Old 07-19-2011, 11:07 PM
BigJared's Avatar
BigJared
BigJared is offline
Well I finally got time to work on it. I rewired the injector harness on the engine.
because of the differences of the old firing order versus the new H.O. firing order. The injectors fire in batches that follow the firing order. Because of this there was puddling of fuel or something causing the single fuel injector to see a lean condition and telling the computer to send more fuel.
Now all I have left is the "surging" at idle.
Thanks to you all.
Old 02-15-2013, 07:26 PM
makingaZJ's Avatar
makingaZJ
makingaZJ is offline
Thanks to you all.
Hey man i have a 89 with a mustang 5.0 ho around the same specs, and you can watch the gas needle fall while it sits in the driveway!! x2 smell it ect..
what exactly did you rewire? how? im still running everything stock for the truck as of now, besides the firing order of course..
thanks
-Nate
Old 02-15-2013, 09:24 PM
Conanski's Avatar
Conanski
Exactly what wiring changes did you make? The batch system fires 4 injectors at a time so I don't see how it would make any difference.
hambone460
15
03-25-2022 03:27 AM
Rich G
13
04-27-2017 05:42 AM
ShaneNP123
15
03-21-2016 02:11 PM
jimbo beam
10-22-2011 06:59 PM
earlybroncoboy
05-06-2007 09:24 PM
Quick Reply: 93 F150 Running WAY TOO rich
