efi 460 running extremely rich
Old Mar 13, 2017 | 10:53 AM
hambone460's Avatar
hambone460
1997 ford f250hd 4x4, 460 efi motor. ever since we put headers on my truck and 3" true duals, it has been running very rich. the o2 sensor is placed in the driver side pipe and it is throwing a lean o2 sensor code, could this be why? can the o2 sensor richen the af mixture that much? it smokes at idle and smokes when i get into it, and fuel mileage is crap. like 6 mpg. smog pump is deleted, egr tube is closed off, intake tube horns are cut off,msd rotor cap with accel coil and 8mm wires
Old Mar 13, 2017 | 11:06 AM
'89F2urd's Avatar
'89F2urd
No other codes? Where did you put the o2?
Check fuel pressure (and make sure the pressure regulator isn't bad, pushing fuel into the intake manifold), and check for leaks in the exhaust upstream of the o2.
If those check out, unplug the o2 sensor (forcing open loop) and see if it's the computer causing the rich condition. If it stays rich, you likely have a sticky injector that is staying open.
Old Mar 13, 2017 | 12:48 PM
Glaser67's Avatar
Glaser67
I had similar situation; running rich and throwing a lean code. When I red the plugs, one cylinder wasn't getting fuel (bad injector condition). The o2 picked up the fresh air and richend the mixture. I know its a long shot, but after you check for upstream leaks, maybe read the plugs. Like previous post said, could be one stuck open. Another way to tell is to put stethoscope on the injectors and listening for the tick.
Good luck,
-Glaser67
Old Mar 13, 2017 | 06:42 PM
hambone460's Avatar
hambone460
It runs really rough at idle, missed a lot, could a stuck injector be why? Or is that just a symptom of it running so rich
Old Mar 13, 2017 | 06:47 PM
'89F2urd's Avatar
'89F2urd
It could bewhy for sure. Easy way to test for a stuck injector is to downshift and engine brake down a steep hill. Get the rpm up to 3000+ with no throttle on decel. With the rpm above idle, and 0 throttle, the computer commands 0 fuel from the injectors (In other words, they're "off"), and it should be smooth. If the engine is stumbling and fumbling on decel with 0 throttle, an injector is stuck.
Old Mar 13, 2017 | 11:40 PM
Dima's Avatar
Dima
My cousin has been through the same issue, he has a 96 460 mated to a zf5. We took the boat out to the lake for the morning, and when we returned it was idling so rough it sounded cammed. Backfiring if I eased up on the gas too quickly. A quick check on prodemand5 and we replaced the injectors, changed nothing. Replaced the spark plug wires, and it was fixed! Hopefully this will help.
Old Mar 14, 2017 | 09:21 AM
hambone460's Avatar
hambone460
spark plug wires, rotor and cap, plugs, etc. are all new. i dont exactly have any hills here in delaware so how else would i check the injectors?
Old Mar 14, 2017 | 09:26 AM
Glaser67's Avatar
Glaser67
Any autoparts store should sell a mechanics stethoscope. It's like what a doctor uses except there is a rod on the end. With engine idling, place the rod on an injector body and you will get a distinct click from the injector firing. It will tell if one is either dead or stuck open.
Did you double check that your wires are right after you put on the headers?
Old Mar 14, 2017 | 09:32 AM
hambone460's Avatar
hambone460
wires are correct, used the haynes manual and replaced one wire at a time, all tight and right. could the timing be an issue causing it to run so rich?
Old Mar 14, 2017 | 09:36 AM
Glaser67's Avatar
Glaser67
I doubt timing could do that, even if its far off enough that the truck still runs. The plugs can tell you alot. A stuck injector will leave a plug black and smelling like fuel, or dead injector would be cleaner looking than the others. To rule out an injector issue pick up a stethoscope at the parts store for $10. Post pics of them if you can.
Old Mar 14, 2017 | 11:11 AM
vjsimone's Avatar
vjsimone
"ever since we put headers on my truck" here is the key......
Check the output signal of your O2. 0.1 - 1.0 vdc?
How far from the original location, did you install the O2?
Old Mar 15, 2017 | 10:15 AM
hambone460's Avatar
hambone460
the o2 sensor is in roughly the same distance as it was stock, just in the driver side pipe of the true duals instead of the y pipe from the stock exhaust.
Old Mar 15, 2017 | 10:19 AM
'89F2urd's Avatar
'89F2urd
Do the other things I suggested, check fuel pressure regulator and pressure, then unplug o2 to see if it is computer demanded fuel ...if the fuel pressure and regulator are good. Gotta rule out some easy stuff here.
Old Mar 23, 2022 | 05:08 AM
Cchee's Avatar
Cchee
What scanner do you use to pull codes? I am currently using a scanner for an OBD1. The only codes I am getting are key on engine off. How do I get codes for key on engine running?
Old Mar 23, 2022 | 06:10 AM
rla2005's Avatar
rla2005
It would be best to start your own thread instead of digging up one that has nothing to do with your question(s).
Page 36 of this manual: https://csr.innova.com/Content/Manua...anual_3145.pdf
