raw fuel smell burning eyes
Old 07-01-2011, 10:04 PM
myred's Avatar
myred
myred is offline
I have a 94 1/2 turbo and when i first got my truck couple years ago never noticed the very strong smell.. We will all get in the truck fast if the wind is blowing toward the doors to keep the smell from coming in cab. Truck runs good,, noticed starting there is a delay at start and it shutters at times while starting and some white to bluish smoke just for 15 sec and clears up.. Not complaining at all but the burning eye smell. What could this be?? PLease hope someone can say this is what i did and fixed it..
Old 07-01-2011, 10:19 PM
Talyn's Avatar
Talyn
Talyn is offline
It's your un-love for diesel in the face!
J/k
I wish I could help on this one.
i get a whiff every now and then myself.
Old 07-01-2011, 11:58 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
You have a fuel leak, start looking or smelling. I'm serious about the smelling, if I have a leak my wife knows it right away. The white or blueish smoke might be injector O rings starting to go. The shuttering is probably the fuel system catching up with the fuel circulation from the leak (air in lines).
Old 07-02-2011, 06:44 AM
RRranch's Avatar
RRranch
RRranch is offline
Sounds like an exhaust leak. The most common place for exhaust to get in the cab is the white insulator under the shifter boot. Pull up the 4 screws holding the shifter boot down and see if it's all torn up under it. If it is then fix that first. I can find you the part number for a new one if you need it. The turbo outlet is he most common leak on them.
Old 07-02-2011, 12:24 PM
Action4478's Avatar
Action4478
Action4478 is offline
I had the same problem until I changed the IPR ...
Old 07-03-2011, 10:18 PM
myred's Avatar
myred
myred is offline
I want to let everyone know its coming from the exhaust.. IPR sounds like a area i can check.. does anyone else have any ideas? Can you take the IPR and clean it??
Old 07-03-2011, 11:18 PM
oldbird1965
Probably injector O rings if its coming from the exhaust.
Old 07-05-2011, 09:42 PM
myred's Avatar
myred
myred is offline
how could i tell if its the injector orings???
Old 07-05-2011, 09:43 PM
myred's Avatar
myred
myred is offline
how could i tell?
Old 07-05-2011, 09:50 PM
oldbird1965
Just a guess, I'm not sure of any other way for fuel to get into your exhaust. How to tell for sure, I don't know.
Old 07-06-2011, 12:30 AM
joe_13894's Avatar
joe_13894
joe_13894 is offline
In my case it isn't in the exhaust, it is from the fuel pump. It isn't much of a leak, but for whatever reason it really gets into the air intake for the heater. If I flip it to recerc when I stop I don't get any in the cab.
Old 07-06-2011, 08:09 AM
Action4478's Avatar
Action4478
In spite of what was said on TDS , IPRs Are usually worn & sticky , not dirty ..
You may want to get the truck on a scanner & get us some live data . It will be worth it ..
green_95
11-20-2015 08:49 PM
breedo99
06-23-2015 10:19 AM
Johnsdeere
04-23-2013 10:00 PM
mgmoore7
12-25-2012 10:13 AM
xikar
04-15-2011 05:37 PM
Quick Reply: raw fuel smell burning eyes
