Cruise Control Fuse?
Old 06-12-2011, 08:09 PM
mah77's Avatar
mah77
mah77 is offline
My cruise control stopped working today on my trip back from Yosemite. Tried looking through the owners manual, but apparently it doesnt have its own fuse. Everything else seems to work just fine, so Im gonna start there.
Old 06-12-2011, 08:36 PM
snorindad's Avatar
snorindad
snorindad is offline
I believe it is #12 in the engine compartment (drivers side). Mine quit a few months ago and it was the clockspring. About $80.00 at dealer. It also fixed me airbag light that was on at the same time. Some say your horn will not work if the clockspring is bad. but my horn worked so go figure.
Old 06-12-2011, 09:32 PM
mah77's Avatar
mah77
mah77 is offline
No ABS light, horn works, along with all the other steering wheel controls. Just checked every "viewable" fuse, and nothin. The search continues. It worked earlier today, then stopped working after I fueled up.
Old 06-13-2011, 07:48 AM
snorindad's Avatar
snorindad
Thats how mine quit after I stopped for food. I did nothing about it for a month or two and the abs light came on. It could also be the switch on the end of the master cylinder it is about $20.00 at the dealer. There are two it is the one closest to the end or front of truck. I replaced it first and did not fix for me though but has for some it is a cheaper place to start.
Old 06-13-2011, 09:29 AM
mah77's Avatar
mah77
mah77 is offline
Do you have a part number? I'm assuming the resevoir need to be drained for the swap. From what I've read, some say the "clock spring" may need to be replaced.
Old 06-13-2011, 10:55 AM
snorindad's Avatar
snorindad
don't have a part number but many have said after replacing the deactivate switch on the master cylinder it solved the problem. no you do not have to drain it you will get a little fluid out when you pull it out and if you put the new one in right away you will be ok. Like I said that did not solve my problem had to change the clock spring and that takes about an hour to do just use caution when removing the air bag. There is a procedure for doing that.
Old 06-13-2011, 06:57 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
First off, there is no fuse for the cruise control on a 6.0L. The cruise is entirely a function of the PCM.
Second, follow the diagnostic in the link below and report back. There are two switches, the Brake Pressure Switch on the master cylinder, and the Brake Pedal Position switch on the brake pedal that can both fail and cause problems with the cruise control. The clock spring can fail, and the cruise buttons can fail. Following the diagnostic will help identify the problem.
https://www.ford-trucks.com/forums/9...ml#post8315477
Old 06-13-2011, 09:14 PM
snorindad's Avatar
snorindad
I asked the same question on this forum about the fuse and got a reply to check #12.
Old 06-13-2011, 09:25 PM
dchamberlain
Fuse #12 in the Power Distribution Box says it's for the Brake Pressure Switch, so it appears that it's possible that if that fuse were out the cruise control wouldn't work.
My truck is older and doesn't have this fuse.
Old 06-13-2011, 09:33 PM
snorindad's Avatar
snorindad
I did a search about this problem a few months ago and I wish the thread you gave the link to would have come up. That has some very useful info on it. I had the same symptoms but the culprit was the clock spring for both.
Old 06-15-2011, 09:53 PM
mah77's Avatar
mah77
mah77 is offline
I tried this, but never got the cruise indicator to flash.
Old 06-15-2011, 10:17 PM
dchamberlain
That would seem to indicate that either the switches are bad, the clockspring is bad or the wiring in the column is bad.
Old 06-15-2011, 10:59 PM
snorindad's Avatar
snorindad
The clock spring is the wiring for the cruise control in the column I thought. So that would narrow it down to either the clock spring or the switches. My bet would be the clock spring from everything I have read and my experience. Although it is not my money.
Old 06-16-2011, 02:28 PM
mah77's Avatar
mah77
mah77 is offline
Where's the best/cheapest place to get a new clock spring?
Old 06-16-2011, 04:30 PM
snorindad's Avatar
snorindad
Don't know if it a dealer item only or not but I got mine from the dealer for $73.00 I believe.
Quick Reply: Cruise Control Fuse?
