egr valve problems
Old 06-08-2011, 06:57 PM
specialK4464's Avatar
specialK4464
specialK4464 is offline
egr valve problems
so i took off my egr valve today and cleaned it. put new orings on it and a new gasket at the bottom where it meets the manifold. the whole top compartment on the valve itself was full of gunk. i put it back on and started it up. it ran fine for about 10 seconds then did a loping type of thing for maybe 2 seconds. took it for a ride and every oce in a while it would do the same thing for about 5 seconds, while loping puffing little clouds of grey smoke. then when the loping went away, a pretty good size of black smoke would puff out and it would run like a dream until it happened again. and suggestions. thanks in advance.
Old 06-08-2011, 07:10 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
sometimes cleaning dont work EGR valve just need to be replaced
was it throwing any codes
did it run this way before you cleaned it??
Old 06-08-2011, 07:20 PM
specialK4464
was not throwing codes, nor running like it did. it was running fine, i just was doing some preventative maintenance. would it still run like that if it was unplugged?
Old 06-08-2011, 08:22 PM
texans's Avatar
texans
texans is offline
You can try unplugging the valve and see if that clears the problem. If it does it's time to change the valve. When you unplug it make sure the keys are out of the ignition so that you know the valve will be closed.
You may have knocked off some carbon build up when you pulled the valve. Try running the truck real hard for short burst to clear the system out.
Old 06-08-2011, 08:47 PM
specialK4464
ok, i got to looking, and i found some things i might be interested in. if i replace the egr valve, could i get the bulletproof egr cooler? or would i be better off doing an egr delete completely?
Old 06-08-2011, 09:01 PM
texans's Avatar
texans
texans is offline
If you have an egr cooler failure I would highly recomend putting in a bulletproof egr cooler. They have very little to know failures.
Old 06-08-2011, 10:06 PM
steelhead2's Avatar
steelhead2
steelhead2 is offline
What did you clean the valve with?.
Old 06-08-2011, 10:22 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
[quote=specialK4464;10438 would it still run like that if it was unplugged?[/quote]
yes if its stuck open
like op said you can try unplugging while the key is in off position [valve closed] and see if symtoms improve
becareful the fan dosent work right with th egr unplugged it might get hot
Chief Many Inches
01-04-2015 05:43 PM
psd96
10-17-2012 09:08 AM
cooper984
08-18-2012 06:43 PM
snsgraham
Modular V10 (6.8l)
07-05-2006 02:41 PM
Quick Reply: egr valve problems
