OD Light Flashed a Couple of Times
The reasons that the torque converter gets so hot in reverse is that it almost always is very low speed so that there is a lot of torque converter slip. First gear usually used at low RPM for a second or two as the truck accelerates. Reverse can be at low speed for a long time, depending on how good the driver is at backing up.
The other reason is that there is little or now airflow over the trans cooler in reverse. You don't have this problem going forward.
Hey Mark, your a master of these 4R100s, does what I posted sound legit? I've talked with a couple of transmission shops and have gotten some differing opinions but between talking to them and doing some of my own research the posts above are the conclusions that I have arrived at. Based on my previous posts, what would your diagnosis be and what would you expect to need replacement when I have the transmission dropped?
Thanks
Thanks
SLE I would like to be there and see the BSEG on your face the first time you pull after the gear change . I checked and you will only be 50 rpm less than I am at 60 mph in third gear with your 285/75 32.8" tires 4.56 gears and my 215/85 30.4 tires 4.30 gears. You will also find that pulling in OD is not a problem at all and the same goes for backing the trailer.
Denny
Denny
Yeh, you know my history Denny. I've went back and forth on this gear change a number of times over the years. Right now I'm currently pulling a 31' two slide fithwheel that has a GVWR of 11,500#s and my 20' Yarcraft boat that I believe to weigh around 4,000#s when full of gear and fuel. The last couple of years I have really struggled pulling this load. When conditions are right and the wind ISN"T blowing, it does alright. Actually, it even kind of impresses me considering what I'm putting the truck through. On the other hand anytime the wind IS blowing I almost dread the trip to a from the lake as I know I'm gonna struggle to stay in third gear and will be in second alot. I'm don't know if I'm asking for a miricle out of this ol Superduty but I'm really expecting the gears to make it considerably better, maybe I'm setting myself up for disappointment, I sure hope not!
Basically from what I've been told is the TC doesn't lock up under load in reverse hence it is easy to bake the TC and fluid when backing heavy trailers up, especially up hill which is what I was doing, go figure. I drove 150 miles with the boat and camper in tow and a GVWR of over 20k lbs yet I baked the trany backing only the camper up a small incline that took less than a few minutes, that sucks!
From what I understand is you can actually get the TC and surrounding fluid extremely hot this way without heating up the rest of the trans enough to even move the gauge (my gauge never moved from center). When this happens the seal at the front gets soft and leaks trans fluid. Once cooled down they will often times reseal themselves and quit leaking, sometimes only for a short time, sometime indefinately.
Higher numerical gears will make a BIG difference in transmission and torque converter temperatures. I think getting the gearing right for your load will fix your problems.
Denny
The appointment has been made for a freshing of the tranny and a new set of 4.56 gears for the front and rear. The truck will be dropped off Monday morning for the tranny work and the gears will follow. Sounds like it'll be 2-weeks or so before I get it back but I will be anxiously waiting to hook up to the train at the end of the month as I have a 9 day camping trip planned. I'll certainly report back with results when it's all said and done. Also had a good talk with mike about getting some updated tunes for the new gear set and he also mentioned that with the 4.56s it should be a real stump puller. We'll soon see. Thanks for the help guys.
Mine did this when I started having misfires (very slight). When I tried pulling out of the drive way, it would get no power to the wheels at all and almost felt like it stalled but then it would catch and go. OD light would flash during that, periodically flash when driving. A scanner will catch the VSS code, changed the VSS, still got the flashing OD. Scanner got the VSS again. A month went by, still doing the OD flash. Misfire got worse, changed plugs and had to change 2 Coils. No problems since!
So check your plugs and Coils. Also heard of this happening with an alternator going out. It has something to do with electrical problems cause your trans to throw the "problem light" (OD Flashing).
Almost willing to put money on it that its your plugs or coils or both...Goodluck
Sorry to hear about your trans troubles, I've been there many times with GM vehicles and it's never fun or cheap. I know this is not going to help save this trans, but I always put my truck in "4-low" when jockeying my trailer around. That way it's easier on the trans and you don't even need to touch the throttle most times to get it to move easily.
#28
Sand_Man, using 4-low for jocking trailers is the right thing to do. My trany guy even said that it would of help avoid what happened. I should probably clarify that the ol 4R100 isn't completely toast, it simply blew some fluid out of the front seal and it may or may not leak again. Since I'm pretty particular about my stuff I'm gonna have the trans dropped to repair the font seal and it only makes since to have them freshin up the rest while it down. In all actuallity I might have been able to get away with changing the fluid and filter and I might not have had another problem. It also gave me an excuse and some amunition to get the gears changed when talking with the wife, gears being something I've talked about changing for years!
Stopped by the shop to grab my phone charger and the shop owner said parts should be in today (firday) so he planned to hit it hard next week. I cann't wait to get it done and see the difference when towing the train! Should make a new truck out of it!
solareclpse2000
06-11-2018 04:21 PM
pbjosh
09-07-2016 02:46 PM
