finally pulled codes... need help
Ok guys, 94 f150 5.0 4X4 a4od. I posted awhile back about hard shifts and jumping speedo, you guys recommended I pull codes. So I just did it with the CeL and this is what I got 123 145 262 845 I went through it a few times and that's what I came up with. Defiantly can be confusing. So any help with those codes would be great, truck is really starting to act up. Thanks guys.
Here's a rundown..
123: Throttle posistion sensor above maxium voltage
145: ?
262: ?
845: ?
I can't help you on the "?"'s for codes not listed. They aren't listed in my Ford Code Reader book. You may need to re-run the Self-Test again, and be sure you are getting the correct codes listed as "?"'s
Hope this helps.
EDIT:If code 145 is actually 144, it means "HEGO sensor switch fault".
145: ?
262: ?
845: ?
Hope this helps.
for your throttle position sensor you can test it very easily, all you need is a multimeter. I just went through this, not like you, nothing transmission related, but I had to test the PTS as well as other sensors. I found a video on youtube that goes through the process.
good luck and it would definetly help if you verify the other codes. Oh and i don't think it matters but my truck is a 96 with obdII
<iframe width="480" height="390" src="http://www.youtube.com/embed/lJEGigONelc" frameborder="0" allowfullscreen></iframe>
I would try to get the codes again before spending too much time diagnosing a potential problem. If there aren't definitions for the codes, they aren't valid codes. There is a diagram here that may help decipher the blinks and pauses (the example is 2-digit, but add another 2 second pause and flash before the 4 second pause): EEC IV Self Test hookup
You can get Equus 3145 code reader here:
Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
4.9LOldFordTruck
12-14-2015 08:36 PM
buzter
Modular V10 (6.8l)
05-12-2015 12:04 PM
Deadman2891
07-17-2004 10:39 AM
