21 OBDII Codes!!??
21 OBDII Codes!!??
I checked my father-in-laws 2002 Expedition today, from what I can tell the transmission is going into limp mode. My scanner finds 21 trouble codes.
p1747 p0750 p0755 p1747 p0750 p0755 p0743 p0443 p1451 p0743 p0443
p1451 p0135 p0141 p0155 p0135 p0141 p0155 p0161 p0401 p0301.
I looked up a lot of these codes, there are a lot of transmission codes, 02 sensor codes, MAF codes, EGR codes. This is a relatively low mile truck which previously ran pretty well, and the engine still sounds nice and smooth.
My thoughts was that it was something electrical, maybe a relay, or something shorted out. I did notice that he had a slow leak from his master cylinder, maybe that shorted something out? Was wondering if anyone has had a problem like this. Thanks.
I know the misfire code was fixed in the past im sure some of the other codes may have been as well.
Immediately after clearing the codes I had 15 pending codes. He has to drive It tomorrow so I planned on seeing what codes it had tomorrow after work. The AC just went out as well he just informed me as I am writing this reply.
You have a blown fuse: The one that is common to all those sub-assemblies and sensors that are now "off-line".
Find the blown fuse and find the short-circuit that is causing it to blow and you'll be fine.
SEARCH keyword(s) "+fuse +F23" (cut and paste the quoted string into the search box).
As for the "leak from the master cylinder", if that leak is from the switch on the cylinder, someone might want to check to see if recall 05S28 has been done.
It was a blown fuse, or rather a missing fuse, Ive been been meaning to get back on here to reply. We replaced the cruise control cutout switch which was blowing its fuse. My father in law, misreading the owners manual, pulled what he thought to be a spare fuse to replace the blown one. The fuse he pulled and which was missing was what was causing all the codes. Long story short we finally figured it out. Thanks everyone for your help.
The fuse it was originally blowing over and over was fuse #15 on the passenger compartment fuse box, which was caused by the cruise deactivation switch leaking, which I believe is the recall that you mentioned,projectSHO89. We fixed that - buying the part was easier and faster than driving to the nearest ford dealership. That fuse blew and he pulled what he thought was a spare fuse but was actually fuse #F23. This made matters worse, and caused all of the codes, except for a misfire code, which is another matter I will have to help him take care of soon. I think he has a pretty good idea whats causing the misfire though so shouldnt be a huge problem. I missed your post till today, projectSHO89, where you nailed the problem on the head. Thanks for you help though and if there is a moral to this story, look for missing fuses as well as blown ones.
hi my name is patrick i own a modified ford ranger with a ford 5.0L engine in it
but i am here to get help on my friends f150 he has a verity of obd2 trouble codes that came after he did a tune up on hte vehicle and his mechanic left a anti freezze line off and had fluid sprayed all over the engine bay
ford f150
2002
xlt
triton5.4L
4wd
obd codes as fallows in there groups
obd2 p0750, p1747, p0755, p0743if i am not mistaken these are all tarany codes
the overdrive is stuck in off and the truck seems to be very slugish taking off in from a stand still
p0135,0155, 1131, 1151, 141, 161
i belave thiese to oxygen sensor related but the truck just passed canadain emission test with flyingn colours
and code p0443 evap
can anyone help me please
ford f150
2002
xlt
triton5.4L
4wd
and code p0443 evap
ford f150
2002
xlt
triton5.4L
4wd
and code p0443 evap
gonna try doing a tranny fluid flush tomroow and yes i have cleard the codes and started form scartch still same issues
also gonna do some ohms test on the shiflt solinoids but the o2 sensors codes make no sens seeeing as how it just passed the emiisions i have the read out less then a month old if it helps
rpm 40km (25mile) 965 rpm idle 600
HCppm 6 o
co%0.00 o
NOppm 0 n/A
i was starting to think the harness but i am no experts
thanks in advance
ford f150
2002
xlt
triton5.4L
4wd
and code p0443 evap
HCppm 6 o
co%0.00 o
NOppm 0 n/A
thanks in advance
Try here: 1997 - 2003 F150 - Ford Truck Enthusiasts Forums
paradox78
1997 - 2003 F150
07-20-2016 09:07 PM
TheInsurancePro
1997-2006 Expedition & Navigator
08-16-2010 07:37 PM
