a/c heater control switch wacked
Old 05-27-2011, 09:24 PM
rickthefix's Avatar
rickthefix
rickthefix is offline
my a/c-heater control switch is doing things it shouldn't. the ac compressor runs on any setting except OFF, and the the a/c compressor will quite working intermittently. does anyone have a good source & ford part number for the switch? also would like to know of a good web site to look up ford parts numbers for future reference.
tia,
rickthefix
Old 05-28-2011, 07:47 AM
92nite351's Avatar
92nite351
92nite351 is offline
i had the same problem on my old 2000 super cab i had. i just had to buy a used one off ebay. i wasnt too bad and it was easy to replace..... they are known for this problem and are replaced quite often.
Old 05-28-2011, 08:47 AM
rickthefix's Avatar
rickthefix
i was hoping to get a ford part # so i can source it in aftermarket parts places. my thinking is, if mine & others have the same issues, then i'll be buying another one with the same issues down the road.
Old 05-28-2011, 09:15 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
i think you need to do a few more tests and see exactly what it is doing that it should not. The compressor does run in various positions other than "ac". The compressor is used as a dehumidifier to dry the air. Does ar real good job in defrost... Next, the AC cuts off... when? If you are low on gas (freon), there is a low pressure switch that will turn the copressor off for a a minute or so... What are the vacuum doors doing ? CAn you put the selector to defrost or floor or vent and make the air go where you want ? Is the **** slipping on the shaft or is it tight and turns good ?
Old 05-28-2011, 09:24 AM
92nite351's Avatar
92nite351
i never had another problem after i fixed it. my switched was all messed up it did wierd things for no reason.... a new one is expensive but worth the money to fix the problem
Old 05-28-2011, 09:48 PM
rickthefix's Avatar
rickthefix
i found a good web site with part #'s & great prices:
the switch is only about $21, with a few bucks for shipping
Ford Parts - Mid Tenn Ford Parts
bigdog660
WTB - Parts & other
12-16-2016 04:22 PM
85MOTORSPORTXLT
09-03-2016 10:39 PM
renchr56
1999 to 2016 Super Duty
12-08-2015 12:48 PM
Brooks Rowell
06-20-2014 12:37 PM
Dj300ford
16
10-05-2013 09:35 PM
Quick Reply: a/c heater control switch wacked
