79 heater control
Old Nov 26, 2003 | 01:27 PM
Dj300ford's Avatar
Dj300ford
79 heater control
I have a 1979 F-250 with dual tanks, and needing to replace the heater switch panel. Does anyone know if the control panel with out A/C will work on mine and my has the A/C switch but I'm not worried about the A/C, Just want the heater. Mine also has the fuel tank switch front/rear in the same panel. Thanks for any help
Old Nov 27, 2003 | 08:42 AM
brown 4x4's Avatar
brown 4x4
An a/c control panel is vacuum controlled, and heater only is cable controlled. It would take quite a few modifacations to make it work. Why do you need to switch the whole panel out? What part is bad?
Old Nov 27, 2003 | 05:37 PM
Dj300ford's Avatar
Dj300ford
The blower control is out, the off low-high switch
Old Nov 27, 2003 | 06:01 PM
brown 4x4's Avatar
brown 4x4
The blower switch and fuel tank selector switch both can be removed separately once you unscrew the heater control and pull it out a couple inches. You might try taking the blower switch out and taking it apart and cleaning it first.
Old Nov 28, 2003 | 08:20 AM
Vince dEon's Avatar
Vince dEon
DJ, that's good advice from Brown. Worked for me when I had to fix my blower switch.
Old Nov 28, 2003 | 04:11 PM
Supercab's Avatar
Supercab
Cool
I changed out my blower switch several years back from Ford, they might be available in aftermarket by now, but I've heard that Ford no longer has the part available, I've been told that they have the switch still, but you must order it for a hevier truck application say a 80s-90s F600 or L9000, I'd take your old one in with you to be sure and get the right one.
Old Dec 7, 2003 | 07:57 PM
Duthlerfordparts's Avatar
Duthlerfordparts
Both switches are still available from Ford, and the price isn't too bad. When I bought my truck last spring, I replaced all the switches just as preventive maintenence. For the 1979 application, the tank selector switch is D5TZ-9A050-A, and the fan speed switch is D5AZ-19986-A.
Old Dec 20, 2003 | 12:54 PM
kinkydoints's Avatar
kinkydoints
has anyone heard of Dennis carpenter reproductions
They have all kinds of ford reproductions parts an online catalog
Old Dec 21, 2003 | 02:02 PM
wezol5484's Avatar
wezol5484
ive done this on my truck when my blower motor switch fried due to my relay going out. its easy to replace seprately and is really cheap. u might also wanna check your relay cause i didnt know it was fried till i replaced the switch and everything and went to turn the heater on and it still didnt work.
Old Dec 21, 2003 | 06:37 PM
Mil1ion's Avatar
Mil1ion
Ford didn't *Make* that switch, They just used it .
Some other company supplied Ford with that switch.
So,
Just the switch should be available in the aftermarket.
Old Dec 26, 2003 | 02:21 AM
F350SuperCab4x4's Avatar
F350SuperCab4x4
there are two fan switches.the one on the left of the panel is for the fan speed, low-med-high, the other is on the "vacuum port switch". that switch turns the fan "ON" when you move the control to a/c or heat. if that switch goes out you have no fan. this happened to me last month. when i went to get a new one i found out it is a "DEALER ONLY" item. and it's NOT CHEAP. $135 i wasn't going to pay that much so i took mine apart and fixed it myself. it's easy.
Paul
Old Oct 4, 2013 | 12:12 AM
grizz1979's Avatar
grizz1979
Where is the relay for the heater? something went POP then everything went dead on the truck. everything such as the fan and heater. i have a 1979 f250 3/4 ton with a 400 motor and a auto transmission. camper special. please help the snow is coming. and i also need info on how to replace the fan for the heater. thanks in advance.
Old Oct 4, 2013 | 08:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Holy necropost Batman!
It would be better to start a new thread than resurrecting a ten year old one.
First question, when you say everything went dead, do you mean the entire electrical system as in no lights , starter doesn't turn, etc. or is it limited to the heater?
Next, do you have just heat or factory A/C?
Trucks with just a heater don't have a blower relay but trucks with A/C do.
As for the blower motor, if its just heat not too bad, factory A/C pretty much a pain to replace.
Let us know which you have and we can be a lot more specific.
BTW welcome to FTE.
Old Oct 5, 2013 | 08:57 PM
grizz1979's Avatar
grizz1979
BTW welcome to FTE.
It has a heater and factory A/C. And when i heard the loud pop the heater and the a/c controls went dead as in if you try and turn on the heater,variable speed fan switch, a/c, or fan their all out? checked the fuse under the dash and it is good. It has dual tanks so im sure you know that it has a front and rear tank switch on the right hand side of the controls. that is the only thing that still works it switches from tank to tank perfectly. Everything else on the truck that is electrical works awesome. lights, tail lights, alternator, stereo, cab lights ,ext. Sorry about the Resurrection on the post im still trying to learn. came here because i have nobody. But my beautiful wife 29 and 7 year old daughter, 5 year old boy. and this is our only source of transportation. I live in Idaho and it already snowed once. please help!! Thanks everyone.
Old Oct 5, 2013 | 09:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The blower relay (Ford calls it a safety relay) is up, under the dash behind the glove box.
A bad relay is a common problem but here are a couple of other things to check if the relay doesn't solve your problem.
The blower resistor, this is located in the plenum under the dash. Although usually when this goes bad you'll still have high speed you lose the lower speeds.
Another thing to check is the blower switch itself and the wiring that goes to it. I've found the wiring from the factory marginal and have seen several that I've taken apart have melted wiring going to the switch.
I suspect this is caused by a blower motor that while its still working, is on its way out and drawing higher amperage, causing the wires to overheat.
But first try the blower relay, thats probably the most common problem.
