Whats the best way to install a mechanical water temp. gauge?
I bought a Equus 7232 and am having trouble figuring out the best way to install it on my 1988 4.9L engine.
I found the plug in the block where the plug is now (under #6 exhaust man.)
If I take that out, can I get the right size reducer installed to where everything will seal up tight? The gauge is 5/8-18 and the original probe-nut is 11/16.
Also, I pulled the lower hose off the water pump and got about 2+ gallons out, if I get the plug out will a bunch more coolant come crashing down all over me?
Well anyways Ill update.
I went back to the auto parts store and talked to someone else and figured out they sell a whole kit with adapters they didnt tell me about the first time which made it possible. Much easier to figure out a puzzle when you have all the pieces.
Ended up looking pretty good.
Went to a friends because he has better sheet metal working tools than I do, and thought you all would appreciate a good looking collection of F150's. A 12th gen, two 10th gens, and my 8th gen.
dtgl90vt
34
11-01-2017 04:04 PM
miteldan
08-24-2016 05:19 PM
JJock
19
12-19-2012 10:07 PM
