Help 93 exploder stalls when temps over 100f
Aftermarket fuel pump or Ford? The first time I replaced my fuel pump I had a similar problem. Turns out the new aftermarket pump I had put in would "overheat" in hot weather and shut down.
Diagnosis of this started with a fuel pressure test. I put my fuel pressure gauge on it when it stalled/wouldn't start and could only get 10-20 psi out of the fuel pump. Engine seems to need at least 25 (spec is 40) psi to start.
Gettysburg150
09-01-2015 05:44 PM
