My 2011 5.0 "Grill Opening" Solution
Old 05-18-2011, 01:14 PM
msuforeman's Avatar
msuforeman
msuforeman is offline
Just fill the void with something useful!
Old 05-18-2011, 01:30 PM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
A Chevy recovery device? Great idea!
Old 05-18-2011, 02:08 PM
Rutcutter's Avatar
Rutcutter
Rutcutter is online now
Thats a great spot for the winch,very nice!
Old 05-18-2011, 02:24 PM
Justjimmy's Avatar
Justjimmy
Justjimmy is offline
Niiiiice!
Old 05-18-2011, 04:32 PM
ebexp94's Avatar
ebexp94
ebexp94 is offline
That's excellent! Looks great! I would love to try to replicate what you've done. I want to put a winch on my truck, and I also hate that opening in my bumper.
I would be very grateful if you would do a short writeup on this, or at the very least a list of the products you used.
Old 05-18-2011, 04:33 PM
awq134's Avatar
awq134
awq134 is offline
how much did that set you back, and how was the install?
Old 05-18-2011, 04:53 PM
msuforeman's Avatar
msuforeman
I used this setup: It was $420 with shipping
Ford Raptor Winch Mount
I know it says its for a Raptor but it fits like a glove. Sorry, but this will be very short.
Take the bottom air dam off
Take off the four bolts that hold on tow hooks and removed hooks
Take four nuts off that hold on bumper but DO NOT remove bumper
The kit comes in 2 pieces---Winch mount and roller fairlead mount. Put roller fairlead mount on first. You will use two of the four holes that mount bumper on to frame. I had a problem with the roller fairlead mounting flush. It lacked about .5". Well, on the front of my frame there was a small 1" square steel tab that had a hole in the center of it where I guess some option went to (nothing went to mine.) I just took 4 seconds and cut it off with a sawzall because it served no purpose.
I then flushed up the roller fairlead mount and sandwiched it in between bumper and frame and stuck all four bumper nuts that I took off earlier back on--Did not tighten all the way.
Then I mounted the winch mount to the four holes of the tow hook mounts and put those bolts back on---Did not tighten all the way.
Then I bolted together the roller fairlead and the winch mount with the 2 bolts provided.
I then tightened everything up and slipped the winch on from the top and bolted it down.
Make sure you get your bumper straight because there is a little play in the bumper adjustment.
With 2 people it takes about 1-1.5 hours to install.
Back 7 years ago I would have cut and welded my own mount because it is rather simple. But now I have 3 kids and more money then time I decided to buy the mount instead. I dealt with Serena at SDHQ and it was sent to me in 3 days--Great customer service over there.
Old 05-18-2011, 05:09 PM
awq134's Avatar
awq134
awq134 is offline
thanks for the quick writeup. How much would you say the winch cost... this is already going beyond my budget
Old 05-18-2011, 05:23 PM
ebexp94's Avatar
ebexp94
ebexp94 is offline
Whoa $420 for the mount? I think I might try to fab something up instead. Too bad its on your truck already or I'd ask you for some measurements.
Thanks for the write up though.
Old 05-18-2011, 10:20 PM
msuforeman's Avatar
msuforeman
Don't know---I've had the winch for going on 15 years.
Like I said--most of my fabs days are behind me. The time I used to take building bumpers, sliders and roof racks are now being spent on the soccer/baseball fields. $420 was not out of the ballpark for me.
Brian
Old 05-19-2011, 05:48 AM
juneau76's Avatar
juneau76
juneau76 is offline
Looks good. I like the cover over the winch to keep the junk out.
Old 05-21-2011, 10:26 AM
No.Va.F150's Avatar
No.Va.F150
No.Va.F150 is offline
That looks tough!...Too bad I'm broke.
Old 05-21-2011, 08:44 PM
Razorbak's Avatar
Razorbak
Razorbak is offline
just thinking of doing this on my truck..great idea...thanks for the tip
Old 05-23-2011, 12:56 PM
rb48f6's Avatar
rb48f6
rb48f6 is offline
Nice set-up and use of the space. Have you noticed any change in cooling temps and did you replace the rubber flap between lower rad mount and bumper?
Old 05-23-2011, 04:37 PM
msuforeman's Avatar
msuforeman
I havent paid any attention before or after on the temps. I did not replace rubber thing--went to trash.
ranger429
212
11-10-2013 09:55 AM
jowens1126
1978 - 1996 Big Bronco
03-22-2013 07:41 PM
AbandonedBronco
11-14-2011 08:49 AM
powrstrkr
New Mexico Chapter
11-10-2009 06:14 AM
powrstrkr
New Mexico Chapter
13
10-15-2008 05:22 PM
Quick Reply: My 2011 5.0 "Grill Opening" Solution
