Using Seafoam
on
My 67 Imperial (440) had a sticky lifter, same thing....quieted down when warm. Did the full seafoam treatment through the vacuum line on the brake booster. Not my imagination but the lifter noise is gone, car starts better, idles smoother and throttle response improved. I don't think I would use it on my newer vehicles but it sure seems to be an 8 dollar mechanic in a can on the old ones.
It should be ok on newer cars, I've used Seafoam through the brake booster vacuum line and in the fuel tank on my 1997 Honda Del Sol and on my Sisters 2002 Toyota Camry and we had improvement in both vehicles. One of my neighbors have used it on his 2009 F250 Diesel.
I've also used in on my 1991 F350 7.3IDI DRW and my Dad's 1989 Chevy 3500 350ci.
yep just like everybody else said, add some into the oil but dont leave it like that too long. also, try to drain the oil while the motor is still warm to prevent all the debris from settling at the bottom of your oil pan and not coming out with the old oil.
