97 PSD slow accel/rough idle
97 PSD 4x4 260~ miles. It has been running weird for a while like the idle was kind of rough, then it sat for months before the tranny was rebuilt. So after trans was rebuilt it would lose power going down the highway where the throttle was not engaging as it should be but it would finally catch on and go. So I ordered up the fuel bowl o-ring kit and FPR kit and replaced those a couple days ago along with the black fuel filter. I also put in a DB high torque starter because stock one died and two new batteries.
So I had a leak on the fuel bowl from an o-ring not seated correctly and fixed that today and started her up. No leaks. It takes around 4+ seconds for it to start even when warm and just shut off. When I first started it up it was idling kinda rough, loping kinda I guess it was weird, and when I went to take it around the block it was like it did not have any power at all, going really slow. Eventually after a couple times it kicked in and went around the block. Stopping at a stop sign it would idle rough loping and be hard to take off again. I disconnected the EBPV connector and that seemed to help a lot but it is still doing it. The ICP had oil in it and I cleaned that up and ran it unplugged but it would resort back to the same thing. Unplugged the MAP sensor and checked line and would resort back to same thing.
Seems to me it might be the fuel pump but I did not have a fuel pressure gauge to hook up. If anyone could point me in the right direction I would really appreciate it. The truck also has a bullydog chip(i know i know) and there is no smoke at start up. Thanks
It sounds like it is oil related to me. As you know, we need clean fresh oil. When was the last time you changed it? I would change it and see if you can tell the difference.
Black fuel filter? was it slimy black? If so, you may have algae in your tanks. If you have algae in there you will need to run some biocide through your tanks to kill it.
If it is not slimy it may be you injector O-rings. Have you ever changed them? If you change them you may as well change your GP's too.
So the next weekend I replaced the injector o-rings. I bought a suction device from napa to get the oil/fuel out of the cylinders. I tried my best to make sure I got all of it out and even used my shop vac to make sure I got all of it out. Put it all back together and started to crank for about half second or so and stops dead. (Many cuss words followed). Tried it one more time just because im an idiot and same. Tired and mentally defeated from working on this damn thing all day I went home in a not so good mood.
Came back today and pulled all the glow plugs and cranked it over. Put it back together and it took a while but it started up and seemed to idle fine and better then it was before. Let it warm up a bit and then took it for a little drive. Surprisingly it seemed to run good and I was hoping I did not mess anything up. But after a couple streets I noticed some nice white smoke following me. I parked it and let it sit for a bit and then did another small trip with same results. It still takes 5+ seconds to start and it just doesn't seem right. All symptoms from before a basically gone cept it did romp a little bit after one of the drives i went on. Glow plugs were replaced last year with motocrafts and the harnesses seemed ok but drivers side plugs have a little bit of oil in them. Only when driving it smokes white and when I park it and let it idle it will smoke but then dissapear and revving it in park does not make it smoke.
I really hope I did not mess this truck up. I dont know what to do now any advice would be appreciated. Here is a video of the smoke from the last run. Thanks.
YouTube - VID_20110508_135126.mp4
Well it has been a while and the smoke has gone away. The truck runs better than it ever has except the throttle issue is still there! It will do it randomly it seems but most of the time on turns. The throttle will just cut out, it will sit there and idle but after a couple seconds will kick back in and start driving like normal. When it does this sometimes the check engine light will come on then go back off when it starts working. Codes are P0221 and P0708. I replaced the TPS with a Dorman unit and I thought it might be the TRS and checked it and replaced also.
When I was doing this however I broke the shift cable connected to the trans because of how old it was. Got a new cable in and its adjusted all the way out but now it wont start in park!!! Shifter is sloppy from bushings and I'm going to replace those but the brass bolts in the back are tight. When I am underneath the truck and messing with the shifter on the trans I can push it back about 1/8 inch and it will engage. But it is locked in park for some reason it is being sensitive and wants to be pushed back as far as it can go but thats not gonna be possible with the shifter like it is. Adjusting TRS makes no difference. I'm really at a loss with this thing now. Anyone have any ideas? I've been searching but its not really helping. Any advice is appreciated.
Tater121
20
05-16-2017 02:01 PM
stevestroke01
01-05-2015 07:15 AM
