$30 CARPET KIT
Old 04-23-2011, 09:15 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
Talking $30 CARPET KIT
so i got tired of looking at my oil soaked nasty "carpet" from the previous owner. went to lowes and got 6' of outdoor black with gray specs . lowes makes you buy the 12' width so $30 other wise it would like $15for 6'x6'
anyways here's the before and after .
before
after
now just need to find a new seat
Old 04-24-2011, 06:04 AM
Talltruck's Avatar
Talltruck
Talltruck is offline
Back in the day when my '71 4x4 was my daily driver I had black astro turf in it. It was very easy to clean after a day in the mud.
Old 04-24-2011, 10:30 AM
zenmaster's Avatar
zenmaster
zenmaster is offline
Very nice job, Mike! It looks so much better. I'm surprised you were able to get it to lie flat. Did you use a heat gun to "mold" it to the floor?
New seat cover are available, or you can have it redone by an auto upholstery shop. I just cover mine with a $50 horse blanket.
Cheers,
John
Old 04-24-2011, 11:55 AM
MIKES 68 F100
thanks zen , i used spray glue and pulled carpet flat , there's a couple wrinkles but it's under the seat so no biggy
my seat springs are wasted , so i am in search of a newer donor , a 94f150 part out just showed up on local craigslist .hopefully seat is gray and still there .
Old 04-24-2011, 05:05 PM
JeffsF-250's Avatar
JeffsF-250
JeffsF-250 is offline
Mechanic
That looks really good. I've got what appears to be standard Ford, industrial grade vinyl - complete with what look like cigarette burns in several places - and have been thinking about a budget carpet. Have to check that out next time I'm in to the Lowes.
Old 04-25-2011, 08:52 AM
MIKES 68 F100
a tip for anyone going to do this get a box cutter to cut carpet also replace the blade i went through 3 blades doing this , after a couple cuts it starts pulling the weave.
Old 04-25-2011, 07:00 PM
Mustangtoby2001's Avatar
Mustangtoby2001
Mustangtoby2001 is offline
Here's a tip: if you are putting carpet all the way back under the seat, put the seat bolts in underneath the carpet. After the carptet is in, take your box cutter and cut an X on the bolts, viola the holes are found.
Old 04-25-2011, 08:18 PM
MIKES 68 F100
I USED A SCRATCH AWL ,poked it up sticking through carpet and just cut a circle around it .
MIKES 68 F100
248
05-22-2016 06:19 PM
MIKES 68 F100
77
12-30-2015 01:19 PM
MIKES 68 F100
30
11-18-2015 07:40 AM
MIKES 68 F100
23
11-11-2015 06:56 AM
MIKES 68 F100
07-22-2011 03:34 PM
Quick Reply: $30 CARPET KIT
