Dana 44 questions
Old 04-18-2011, 06:26 PM
1980 Ford F-250's Avatar
1980 Ford F-250
1980 Ford F-250 is offline
Dana 44 questions
When i was pushing the old u-joint out of the passanger side axle shaft, the press ended up bending the piece in the picture to where i cant get the new u-joint in. Could i use the driverside shaft untill i can get to the wrecking yard and get a new one?
Second, how do i remove the shaft coming out of the differential so i can clean and replace u-joint and seals?
Thanks
JM
Old 04-18-2011, 06:46 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I would just use the press to bend the yolk back open so you can put the u-joint in.
As for removing the passenger axle shaft, there is a "C" clip inside the carrier that goes on the end of the axle shaft. Look inside the spider gear on that side. You need to pop that off then the axle will come out
Old 04-18-2011, 07:50 PM
1980 Ford F-250
I looked and did not see the 'c' clip. Did i just not look hard enough or do the gears need to come out in order to remove it?
Old 04-18-2011, 10:04 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
The very first front axles did not have a c-clip, they just had a retainer plate on the outside. After the plate is loose, you just jerk it out of the pumpkin. Sometime later they went to the c-clip style pumpkin. My old 80 did not have the c-clip.
Old 04-18-2011, 10:21 PM
1980 Ford F-250
That sounds about right. Thanks!
Old 04-18-2011, 11:30 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
6fifty_f1fifty is offline
I had to hammer the hell out of mine to get it out, in the process it tore apart the bearing which was unsalvageable.
Old 04-19-2011, 12:13 AM
1980 Ford F-250
I went out with a hammer and it took me 2 minutes and it came out nice and everything was intact. The bearing also looks brand new! The cool part is is i got the truck for $100 bucks, the front brakes were all brand new, the bearings looked to be brand new as well! And NO RUST!!! lol It makes me happy when i find things like that!
Old 04-26-2011, 11:08 PM
1980 Ford F-250
Another thing. The axle shaft in the second picture, I got that out, but now i cant get the bearing retaining ring off the end so i can replace what needs to be replaced. I read that you have to break it off of there but i dont want to do that until i know i can get a new one... Long story short, where can i get that retaining ring?
1980 Ford F-250
11-12-2013 11:50 AM
1980 Ford F-250
121
06-22-2013 03:22 AM
1980 Ford F-250
03-26-2013 08:29 AM
1980 Ford F-250
10-07-2012 09:35 AM
1980 Ford F-250
05-23-2011 08:13 AM
Quick Reply: Dana 44 questions
