1 wire alternator mounting?
Hi folks. I'm looking to mount a 1 wire Powermaster alternator on the passenger side of engine but down low. I've heard that Galaxie alternator mounts might work as they had a smog pump mounted up high where my smaller Ford alternator is mounted. The 1 wire won't fit in the stock location as the alternator hits the head. I'm running an electric fan and need the amperage.
Thanks!
Eric
Thanks!
Eric
Thanks Dave. I found a pic of what I can do. The adjuster bracket will go under the alternator and bolt to the timing cover with a longer bolt and spacer. The top alternator bolt will have a spacer and bolt into the bottom of the head like the old Galaxies that had smog pumps. Electric fans raise havoc on my small radiator.
lots of good info here:
Catalog
but to make a long story short, the 3-wires
1. are much cheaper
2. available at any parts store
3. will allow you to use your dash warning light
4. give you 'remote voltage sensing'
i helped a friend put one into his '47 Plymouth recently. the wiring is really easy. one wire to battery, one wire to ground, one wire to 12v "key-on", one wire to the location you want to use for the remote sensing.
Catalog
1. are much cheaper
Catalog
1. are much cheaper
Catalog
1. are much cheaper
didn't realize it until just now, but there's a tech article right here about this:
One Wire Delco alternator Installation In A Classic Ford Truck .: Articles
the article incorrectly calls it a "one wire", and kind of cheaps out on the voltage sensing hookup, but the rest is good.
i don't have any info on the dimensions, though. good luck!
zoom38
39
03-30-2018 01:53 PM
silar
02-12-2015 09:14 PM
ericr712
11-09-2014 09:29 AM
merc62
04-29-2004 06:39 AM
